Vibration starts at 2000 rpm - SailNet Community
 1Likes
  • 1 Post By T37Chef
post #1 of 9 Old 10-22-2013 Thread Starter
Dave_E's Avatar
Hi All,
Still learning the new inboard diesel thing. I've read about boat/engine "harmonics"... From idle to 1980 rpm or so, you can set a glass of water on the cockpit table without a ripple. After 2000... it's vibration city (compaired to what it was before this crossover point). Where should I go to look for problems? Do I even have a problem? Not sure. The hull is clean and the 2 blade prop is clean and the Universal 5424 will achieve it's max rated 2800 rpm.
Dave
Allmand Sail 31 #15 "Traveler"
GOD, Family, career
Dave_E is offline
post #2 of 9 Old 10-22-2013
T37Chef's Avatar
Re: Vibration starts at 2000 rpm
First, I would check the engine mounts and isolators to see if they are good condition
Second, check the cutlass bearing and strut (if applicable)
Third, check alignment of the shaft coupler. (.001 for every inch in diameter of the coupler ).
Fourth, I would call a mechanic
erps likes this.
Shawn
T37Chef is offline
post #3 of 9 Old 10-22-2013
If you get the vibration when out of gear it may be something in/on the engine. If only when in gear, probably as T37 mentioned. Did it just happen all at once? If so, maybe you lost a shaft zinc or wound up some monofilament in your shaft/strut?
Paul T
dabnis is offline
post #4 of 9 Old 10-22-2013 Thread Starter
Dave_E's Avatar
The boat is new to us, so that's the way we got it. I do know when we hauled it for the survey, the cutlass bearing had just the tiniest amount of movement (to be changed later this winter when doing the bottom). Will look into the rest of it...thanks!
Dave
GOD, Family, career
Dave_E is offline
post #5 of 9 Old 10-22-2013
Gary M's Avatar
Good chance it is shaft alignment, vibration gets worse with RPM.
If it is motor mounts the engine will be moving a fair bit when idling, maybe a half inch or so.
If your cutlass bearing only has a little movement ( 1/8" ??) it is likely alright.
Gary M is offline
post #6 of 9 Old 10-22-2013
Definitely not normal. I have a 5424 and it smooths right out above 2000 rpm. Actually it's good above 1800. Although I have a 3 bladed prop.
Have you had a diver check the prop? A few barnacles can cause a lot of trouble.
MarkSF is offline
post #7 of 9 Old 10-23-2013
Sailor
Gladrags1's Avatar
We are not hearing whether this is occurring in gear or out of gear. It would be important to know to help diagnose.
Tod
Mandolin
Bayfield 36
Sailing out of Rock Creek, Chesapeake Bay
Gladrags1 is offline
post #8 of 9 Old 10-23-2013 Thread Starter
Dave_E's Avatar
Tod
I'll try that this weekend. The post is all about in gear, under way. I did watch the engine under way while the wife went through the RPM range and the engine was solid in it's mounts (no movement at all). Also, the cutlass bearing... MAYBE a 1/16th worth of play.
GOD, Family, career
Dave_E is offline
post #9 of 9 Old 10-27-2013
Stonecutter36's Avatar
Send a message via Skype™ to Stonecutter36
So far no one has mentioned a BENT shaft it is possible that a past owner has wound the dingy painter on the prop shaft It may be only at the taper and hard (imposible)to see It may only appear under a unique load .
I went through this from NY to Datona Beach finally had to pull the shaft to have it check The shaft looked fine except for a wear spot at the cutlass since it was off the boat I sent it out for a weld and machineeing to spec , I received a call that the shaft was (bent)by 1/1000 at the taper A new shaft later and all was go
Stonecutter36 is offline
ST1000/2000 Tiller Pilot and NMEA 2000 nickmerc Gear & Maintenance 2 03-13-2010 11:04 AM
Vibration / Alignment jason3317 Gear & Maintenance 8 08-05-2009 11:20 AM
Vibration ! dbruce85 Boat Review and Purchase Forum 3 12-01-2008 11:14 PM
Vibration mtbmike Gear & Maintenance 7 05-28-2006 12:14 PM
Vibration mtbmike Gear & Maintenance 5 05-26-2006 11:55 AM
