External and internal raw water strainer? - SailNet Community
post #1 of 6 Old 10-23-2013 Thread Starter
WoobaGooba's Avatar
I'm about to have a major refit done this winter on a decades old boat bottom. Seacock replacement will be considered. If I go that route, is there any good reason I should remain with my current external AND internal raw water strainer setup?
WoobaGooba is offline
post #2 of 6 Old 10-23-2013
Sabreman's Avatar
Yes. It's the same reason for multiple fuel filters - to keep bad stuff from getting into the engine. I have the same setup and find sea grass in my second strainer. Not often, but enough. If you aren't racing there isn't a good reason not to have two strainers.
Sabre 38 "Victoria"
Sabreman is offline
post #3 of 6 Old 10-23-2013
chef2sail's Avatar
Re: External and internal raw water strainer?
Same here . Good advice. Sea grass has made it past by primary strainer to the second one. Same with nettles.
Dave
___________________________
C&C 35 MKIII Hull # 76
Parkville, Maryland
(photos by Joe McCary)
Our blog-
chef2sail is online now
post #4 of 6 Old 10-23-2013
Plastic bags and jelly fish are easier to remove from the screen than pulling hoses inside.I even put in a hose bib so I can blow or cool with domestic water. Only used it twice in 30 years.
Capt Len is online now
post #5 of 6 Old 10-23-2013
Personally I can't stand external strainers. With internal strainers they are completely redundant, and frankly cause more problems than they are worth. They commonly geting fouled, are commonly installed the wrong way, and frankly provide minimal protection. Added to the the fact that they can't be cleaned without getting in the water makes them a poor choice.
You also generally need a much larger hole in the boat to ensure proper water flow with an external strainer than you need without one because of the flow restriction from the screen. Most applications come with a specced size of hole in order to allow enough water flow, external screens provide a significant amount of resistance because of the minimal surface area of the screen. Compare that to the surface area of an internal strainer and you can see the issue.
Greg
Stumble is offline
post #6 of 6 Old 10-24-2013 Thread Starter
WoobaGooba's Avatar
And therein lies the issue. I do race, and am considering going with all new flush through-hulls.
Spinnaker Halyards: Internal vs external mast routing mentalfee Gear & Maintenance 5 06-21-2014 05:47 PM
Internal vs external ballast Frogwatch Gear & Maintenance 2 09-10-2012 06:45 PM
GPS Antenna - Internal or External Tafa Electronics 6 02-26-2012 11:30 AM
Internal or external boom lines led aft karluk Gear & Maintenance 5 06-01-2011 05:13 AM
Internal Ballast vs. External Ballast windship General Discussion (sailing related) 3 09-15-2002 04:33 PM
