Yanmar 2GMF, throttle return spring too strong - SailNet Community
post #1 of 11 Old 10-24-2013 Thread Starter
I recently acquired a Pearson 303, vintage 1983, and I'm still getting to know it. Yanmar 2GMF inboard.
A curious problem: the throttle appears to have a return spring, or something similar, which tends to push the throttle back down to the idle position. There is a sort of clamp on the throttle cable housing, which creates enough friction in the cable to oppose this force. But if I clamp the cable hard enough to keep the throttle in the fully-open position, it's so clamped-down I can't move the throttle at all.
There doesn't seem to be any obvious way to adjust the tension on the return spring, or whatever it is, which seems to be *inside* the engine. Is that possible?
Anybody ever encountered this problem? Suggestions?
PS -- Been looking at the service manual, and I'm starting to get a sinking feeling that all this magic happens inside the injector pump... Somebody tell me I'm wrong!
rauschpfeife is offline
post #2 of 11 Old 10-24-2013
On an Edson pedestal there is a bolt to adjust the tension on the throttle lever under the compass.
"Just call me TB"
capttb is offline
post #3 of 11 Old 10-24-2013 Thread Starter
Re: Yanmar 2GMF, throttle return spring too strong
I looked but didn't see one; will look again. It kinda appears that spring tension
is needed from another source to balance the idle-ward internal tension in the fuel system itself.
post #4 of 11 Old 10-24-2013
Irrationally Exuberant
capttb has it right. I had that problem with my Pearson. Assuming you've got an Edson pedestal, the screw is inside where the speed control comes through. Tighten that set screw a tiny bit --it doesn't take much.
Tom K
2000 Beneteau 331
Northern Chesapeake Bay
arf145 is offline
post #5 of 11 Old 10-29-2013
redline's Avatar
On my C&C33 I looked and never found a throttle friction adjustment on the Edson pedestal. What I did find (with help from the person who sold the boat new) was a small u-bolt on the cable which needed a tiny bit of tightening. Always found it odd, but it worked, even though the "adjustment" was a bit touchy.
Norman
s/y "Redline"
1998 Jeanneau SO45.2
redline is offline
post #6 of 11 Old 10-29-2013
The following is from the FAQ page from Edson:
Q4: My throttle doesn't hold when I push it full forward - what can I do?
A4: Some Engine have a very tight spring on the throttle lever. Depending on the Engine Control Model, you may be able to tighten the Throttle Friction Adjuster. Older controls may not have this adjuster, but a "horseshoe" cable-clamp can easily and inexpensively be clamped around the outer jacket of the engine control cable to add the proper cable resistance
"Just call me TB"
capttb is offline
post #7 of 11 Old 10-29-2013
wduncan50's Avatar
I had the same problem on my hunter and had to buy a boat trottle cable brake. It's cheap and simple.
Teleflex Cable Brake - Star Marine Depot
Will Duncan
wduncan50 is offline
post #8 of 11 Old 10-29-2013
You can make your own with a split piece of small hose.. firmly clamp it on the outer sheath with a hose clamp, and lightly clamp the other end on the sliding part of the cable.. adjust the latter tension for the friction you need.
You can do this at either end, whichever is most accessible.
Faster is offline
post #9 of 11 Old 10-29-2013
old guy :)
rikhall's Avatar
A common problem, a very cheap fix:
This was on my brand new Yanmar 2GM20F.
Just tighten until is stays where you want it when you adjust it.
Rik
Irwin Citation 34
Mystery
rikhall is offline
post #10 of 11 Old 10-30-2013
redline's Avatar
If adding a clamp on the cable as pictured above (or the Teleflex version), it's best to put it as close as possible to the control lever end of the cable. If the cable length is significant and/or has several bends, it will add "sponginess" if the clamp is at the engine end.
Also, it shouldn't be too tight - ideally the return spring should throttle the engine back to idle if the control cable somehow let go.
Norman
s/y "Redline"
redline is offline
Yanmar 2GMF problems Kiltmadoc Diesel 6 08-22-2012 02:46 AM
Yanmar 2GMF Transmission Oil? dacap06 Gear & Maintenance 4 04-19-2010 11:03 PM
2GMF Yanmar wp impeller question goletasailor Gear & Maintenance 6 11-19-2009 09:45 PM
Looking for a used Yanmar 2GMF or? captsam54 Diesel 0 08-09-2009 03:43 PM
zincs for Yanmar 2GMF Julie303 Gear & Maintenance 13 11-16-2007 02:00 PM
