Oil overfill in 1gm Yanmar - SailNet Community
post #1 of 15 Old 11-02-2013 Thread Starter
I recently purchased an oil filter and changed the oil on my Yanmar 1gm. I overfilled the oil and ran the motor afterwards. After bogging down with increased rpm I checked oil again to discover I had overfilled.
I removed oil down to half way of stick but still I bog down.
Is my problem a bad oil filter? Did I damage something? Would changing fuel filter remedy as increased throttle chokes motor down? Do I need a pro out to diagnose and repair?
Bayfield 25 in Charleston
charleston is offline
post #2 of 15 Old 11-02-2013
Re: Oil overfill in 1gm Yanmar
"Bog down"? will it reach max rpm as it did before you changed the oil? Is there much exhaust smoke? Any other work done at the same time? Is the oil pressure the same as before? some filters may have differing relief valves.
Maybe excess oil has accumulated in the crankcase breather system, causing an "extra fuel" condition? Let us know what you find.
Paul T
dabnis is offline
post #3 of 15 Old 11-02-2013 Thread Starter
It will not reach max rpm as before. It starts right up but then any throttle above idle causes it to die and shut off as if it is flooding out. The oil pressure light does not come on and I do not have a pressure gauge.
No exhaust smoke and not sure how to check crankcase breather.
Thanks for your reply.
post #4 of 15 Old 11-02-2013
Old as Dirt!
svHyLyte's Avatar
Pull the filter head/cover off your air intake and check the core. It may be sufficiently saturated with oil forced through the breather tube that it will not allow enough air to be drawn into the engine to support higher rpm combustion. Replacing the filter core is pretty easy.
svHyLyte is offline
post #5 of 15 Old 11-02-2013 Thread Starter
Thanks. I will try this. So I need to purchase a new "filter core" and replace it for a probable solution?
post #6 of 15 Old 11-02-2013
No hands on experience with your specific engine. You may have a rubber hose, about 1" in diameter, that runs from the valve cover to the intake tract, either before or after the air filter. As SV said, it may have plugged up the air filter? If it is not smoking excessively, it may be starving for air.
Oil may accumulate in any low spot in the crankcase breather hose or in the intake tract. The air filter is a likely suspect. No other work done at the same time?
Paul T
dabnis is offline
post #7 of 15 Old 11-02-2013 Thread Starter
No other work done except to change oil filter. Have not changed fuel filter and not wanting to yet unless need be.
post #8 of 15 Old 11-02-2013
OK, kind of looks like the extra oil may have found it's way into the intake tract, as SV mentioned. I doubt that the oil filter capacity would vary that much to effect anything.
As mentioned, different filters may have different pressure relief values, but I doubt that would cause your stalling problems unless you have a system that senses low pressure and attempts to shut down the engine. Probably a stretch, however, you might try a genuine Yanmar filter. I have read about some high pressure injector pumps being operated by the engine oil pressure, don't know about Yanmar?
Likely it may be excess oil somewhere in the intake tract.
Paul T
dabnis is offline
post #9 of 15 Old 11-02-2013
Old as Dirt!
svHyLyte's Avatar
The intake filter on the 1GM is on the aft side of the engine, above the bell housing/transmission and somewhat resembles a pot with a long snout, normally facing downward. A couple of cam-lock latches hold it in place. The filter core is either foam or in some cases paper with an accordion fold. In either case, the core can become saturated with oil from the breather tube, which plugs into the side of the filter housing. Frankly the 1 and 2GM motors are pretty idiot proof and very reliable so I would be surprised if you have done any more than foul the intake filter. In future, pay attention to the oil capacity of the motor and the amount you remove during an oil change, including about 1/2-2/3'rds of a quart for the filter canister, assuming you are also replacing the filter. N'any case, don't worry about it. Other's have done worse.
FWIW...
svHyLyte is offline
post #10 of 15 Old 11-03-2013
Sounds like SV has "been there & done that". If the air filter is clean & no oil accumulating, MAYBE, a real stretch, your fuel filter has just decided to pack it in? I can't think of anything else, maybe tank vent , air leak, or other "normal" fuel system related problems. Curious to know what you find. I am assuming it stalls when out of gear?
Paul T
dabnis is offline
8 hp yanmar dennisc Introduce Yourself 6 04-10-2013 03:45 PM
Wish someone would do this for a Yanmar... night0wl General Discussion (sailing related) 8 06-29-2012 06:24 PM
Yanmar 4jh 8te jbondy Diesel 3 10-30-2010 07:30 PM
Old Yanmar NoDestination Gear & Maintenance 13 04-15-2009 07:21 AM
$7,500.00 for a new Yanmar??? deniseO30 Gear & Maintenance 15 07-09-2008 11:40 PM
