Volvo Penta MD 7A water in oil - SailNet Community
post #1 of 6 Old 11-09-2013 Thread Starter
waterrat2's Avatar
Thumbs down Volvo Penta MD 7A water in oil
Hello,
I read another thread about a problem with water in the oil on an MD 7A and wondered if one need do anything special to clean out the lubrication system after finding the source of the water. Should you remove the bottom pan to clean the oil sump or just replaced filter and changed oil? I have "milky oil" but think I have solved the cause and want to clear the oil so I can find out if I'm right.
Also, does anyone have experience removing the oil pan on this engine? It does not seem to be simple as some engines.
Appreciate any help.
Chris
I like sailing a lot better than working on the motor.
waterrat2 is offline
post #2 of 6 Old 11-09-2013
casioqv's Avatar
Re: Volvo Penta MD 7A water in oil
I'd just change the oil and filter, drain it as best you can, and then run it hard for a while. A tiny bit of water doesn't cause a problem as the heat of the engine will drive it off. In normal operation, an engine actually gets a lot of water in the oil from both combustion (when running) and condensation (while sitting) but this is driven off quickly.
casioqv is offline
post #3 of 6 Old 11-14-2013 Thread Starter
waterrat2's Avatar
Thanks for the quick reply. I pumped out the water and old oil and heated and drained the filler. Then I ran the engine for about a half hour before changing the oil again with a new filter. I'm going to run it some more before winter really sets in, but it's not so easy because all of this has been on land and I have to carry the water to the boat in buckets... I'll post how it goes later.
post #4 of 6 Old 11-14-2013
casioqv's Avatar
It may be hard or impossible to drive all of the water off on land, because the engine won't really warm up without a load.
casioqv is offline
post #5 of 6 Old 03-03-2015 Thread Starter
waterrat2's Avatar
That was in Fall 2013. Just in case anyone reads this thread and wonders, after a full season in 2014 running the motor. There seems to be no more water coming in and the motor starts and runs fine. I don't usually use it for long periods – just five to ten minutes to get away from the dock and raise the sails. Once in a while I run it longer just so it will warm up and three or four times I ran for an hour of three when I wanted to go somewhere I couldn't sail. I do have a new problem but will post that on a new thread.
post #6 of 6 Old 03-03-2015
JimsCAL's Avatar
Thanks for posting the update. Glad it all worked out for you. And good luck with the new problem
JimsCAL is offline
Tags
lube , oil , penta , volvo
Replacing Raw Water Pump Volvo Penta MD2010 FionaBowman Diesel 0 05-23-2013 09:26 AM
Volvo Penta water pump shaft question. MD5A GMC Gear & Maintenance 1 04-16-2012 10:30 AM
Volvo Penta Outboard? rhbroehl Gear & Maintenance 9 07-23-2011 01:40 PM
Volvo Penta 39 jernhenrik Gear & Maintenance 0 10-18-2009 12:00 PM
MD3B Volvo-Penta sea water to fresh water conversion slosharron Gear & Maintenance 20 06-17-2003 09:08 PM
