Help with small outboard info - SailNet Community
 3Likes
post #1 of 17 Old 11-20-2013 Thread Starter
Newbie here.
Recently bought a 3.8 m fiberglass sailing/rowing dinghy, [url=http://www.boatsales.com.au/features/2008/runabout/feature-classic-dinghies-10803]Feature:,weight around 50 kg, and want to buy an outboard auxiliary to keep peace with the partner and to use for fishing now and again. Options are 2.5 HP at 16 kg and 4 HP at 21 kg. The 4 HP would be sure to handle a bit of chop, a headwind, and some tide, but the lighter motor has obvious appeal if it's hanging of the transom when sailing, and for general functionality.
Could members help me with their experience/knowledge.
It also appears there are formulas for hull speed prop pitch/diameter to ensure the engine is able to operate at maximum efficiency throughout the rev range. I guess the engine dealer will be helpful with this information but any independent advice would also be welcome.
Looking forward to hearing from forum members.
bgorton is offline
post #2 of 17 Old 11-20-2013
Re: Help with small outboard info
The 2.5 is probably enough power for what you're going to use it for... but rarely do 2.5 hp engines have a 'neutral' position.. ie they start in gear(one way they minimize the weight). Generally you have to go to 3.5 or 4 to get that function. Our 3.5 Nissan has a neutral but no reverse so you still need to spin the engine around to reverse.. not a problem in our small tender.
Overall, if you want gearshift or at least a neutral, that likely puts the 2.5 out of the equation. If youngsters are involved I like the neutral feature..
Faster is online now
post #3 of 17 Old 11-20-2013
My Honda BF2A (2.0hp) pushes my 1000lb daysailor very well. At low rpms the prop stops spinning as if in neutral. It weighs in at 28lbs.
millerandy is offline
post #4 of 17 Old 11-20-2013
The Lehr 2.5 hp propane fueled engine has a neutral. I hate engines you have to start in gear.
hopcar is offline
post #5 of 17 Old 11-20-2013
Cool.. must use some kind of slip clutch??
Good to know, thanks. Maybe the manufacturers are changing their ways!
post #6 of 17 Old 11-20-2013
overbored's Avatar
all the new 2.5 hp engines have neutral and forward, no reverse except the honda it has a centrifugal clutch, no reverse
Suzuki is the lightest with a gear box also the cheapest
Honda 29.5 #
Suzuki 30.1 #
mercury 37#
Yamaha and nissan 39#
"GOLD RUSH" PRINDLE 16
overbored is online now
post #7 of 17 Old 11-20-2013
TQA
Bombay Explorer 44
TQA's Avatar
I think that Honda is the air cooled version. Before you buy one be sure you have a sea trial, there is NO WAY I could live with the noise.
A lot of small modern outboards are made by Tohatsu and sold under different brands eg Nissan.
Out in the cruising world the Suzuki 2hp 2 stroke is much sought after. They just keep ticking.
The Tohatsu 3.5hp 4 st at 41 lbs is a good buy. Quiet and reliable. N.B. the 2.5 is the same engine just restricted and weighs the same 41 lbs.
TQA is offline
post #8 of 17 Old 11-21-2013
Sailor
Gladrags1's Avatar
Your boat should have a plate on it telling you the max horsepower it is rated to carry. It's a good idea to follow that.
Mandolin
Bayfield 36
Sailing out of Rock Creek, Chesapeake Bay
Gladrags1 is offline
post #9 of 17 Old 11-21-2013
I think a 41 kg outboard is too heavy for a 3.8m sailboat. I have a O'Day Daysailer (5.10 m/260 kg empty) and my 3.5 hp Nissan two stroker pushes it very well. Motor weighs 12.5 kg.
Florida Sailor is offline
post #10 of 17 Old 11-21-2013
FWIW we have the same 3.5 Nissan 2 stroke on our tender.. amazingly reliable little engine, has never failed to start in 9 years despite limited use.
christian.hess likes this.
Tags
2.5 hp , 4 hp , fairlite , sailing dinghy , small outboard
Small outboard plastic prop? asdf38 Gear & Maintenance 4 06-24-2013 06:53 PM
Mounting small outboard on stern rail MarkSF Gear & Maintenance 4 06-21-2011 09:28 AM
Small DIESEL outboard?? 3 to 6 hp? SoulVoyage Gear & Maintenance 3 11-03-2010 10:32 AM
Recommendations sought for small outboard Valiente Gear & Maintenance 27 06-29-2007 08:08 PM
Small Electric Start Outboard FRRizzo111 Gear & Maintenance 1 07-06-2005 07:13 AM
