2gm20f won't suck AntiFreeze - SailNet Community
 1Likes
  • 1 Post By Vasco
post #1 of 7 Old 11-24-2013 Thread Starter
Hi All, Had earlier thread that asked for advice on this and it helped, but, I am having trouble getting more then 1 gallon of AF through. When it starts, it starts to kick it out when the stainer output line is in a bucket or the container of AF! I decompressed the engine just to get the 1 gallon in, but now not taking any more. Is it the thermostat keeping it from circulating more? I didn't take it out. I got AF coming out of the drain by the dipstick so does that mean it at least got to the mixing elbow? Or could some lines already be frozen, there were one or two freezes but then melting temps here on the Hudson. I need to boost the batteries to try to start it again, hopefully want to still get more in by holding the strainer line up and funneling it in, and have it come out the beck. (I couldn't reasonably get the hoses off the elbow to get AF into the mixer? or muffler system, they were rock hard-frozen?)
Any advice appreciated.
alechich is offline
post #2 of 7 Old 11-24-2013
Tartan 27' owner
CalebD's Avatar
Re: 2gm20f won't suck AntiFreeze
T-stat should probably come out for this.
Can't you just get the engine running at idle and use the cooling water pump to suck in a gallon or two of pink stuff?
How far up the Hudson are you?
Everybody has one:
CalebD is offline
post #3 of 7 Old 11-25-2013
dockbum
dockbumdan's Avatar
that's strange! my yanmar 3gm SUCKS just fine.
DockbumDan
SV/Trinity
Sailing Associates
Slip W=11
Georgetown, Md.21930
Sassafras River, Md.
dockbumdan is offline
post #4 of 7 Old 11-25-2013
Warm Weather Sailor
Vasco's Avatar
The f in the motor 2gm20f indicates fresh water cooling. No need to remove the thermostat. I suggest the impeller might have been damaged from the previous tries at winterizing. Check the impeller.
christian.hess likes this.
Rick I
Toronto in summer, Bahamas in winter.
Vasco is offline
post #5 of 7 Old 11-26-2013
If there are an air breaks, many impellers won't self prime. If the impeller itself isn't shot, you may have to fill the entire input with AF, then crank it over to get it flowing.
Jeanneau 54DS
Minnewaska is offline
post #6 of 7 Old 11-29-2013
JimsCAL's Avatar
Two possibilities come to mind. Problems with the raw water pump or a plug in the raw water cooling circuit. Based on your description, my vote is on the second. The Yanmar U-type mixing elbow is known for this problem. I would start there.
JimsCAL is offline
post #7 of 7 Old 11-29-2013
I'd also consider the Heat Exchanger if it hasnt seen maintainence in awhile..
http://www.yanmarmarine.co.uk/pdfs/s...al/EPB5494.pdf
..but I highly suspect the raw water impeller..
aa3jy is offline
Bilge Pumps Won't Suck vtsailguy Gear & Maintenance 10 08-30-2012 03:33 PM
Automotive antifreeze vs. RV antifreeze for engine. dman535 Gear & Maintenance 18 09-30-2009 04:53 PM
Antifreeze harpguitar Gear & Maintenance 22 11-26-2008 02:42 PM
It Just Won't Suck- Antifreeze slocum2 Gear & Maintenance 22 10-27-2008 11:47 PM
antifreeze stm Gear & Maintenance 8 02-04-2004 03:53 PM
