Eric's 5416 Rebuild - Page 2 - SailNet Community
 1Likes
post #11 of 17 Old 11-26-2013
One of None
deniseO30's Avatar
Re: Eric's 5416 Rebuild
is following Jim who's following this also. 5416 here too!
My last project!
deniseO30 is offline
post #12 of 17 Old 11-26-2013
ericirvine's Avatar
Hey, I'm following Jim too. Does that mean I'm chasing my own tail
Eric
Eric Irvine
1980 Bristol 29.9
Selkie
ericirvine is offline
post #13 of 17 Old 11-27-2013 Thread Starter
davidpm's Avatar
Hi Eric.
We now have an audience.
Sadly my ability to ask good questions is limited by my extreme ignorance about this subject.
I am curious about the timeline however.
How long did the actual work take?
I know it was spread out over some months but maybe you can guesstimate as to how many hours actually turning wrenches and maybe some warning about the management time.
I always forget about the time spent traveling, shopping, studying, following up.
Also aside from standard wrenches what equipment did you need.
Chain hoist for example?
I searched youtube to find these two very different approaches.
Full Rebuild
https://www.youtube.com/watch?v=1lbH...008754DAACB799
Partial Rebuild
https://www.youtube.com/watch?v=cbAjKuVF1f4
davidpm is online now
post #14 of 17 Old 11-29-2013
ericirvine's Avatar
Hi David
Special Tools? - not much. In my garage, I used a block and tackle (from an old mainsheet system) to lift the engine off the floor. I made a wooden dolly for the motor to sit on from plywood and 2x4's, and made a sort of frame/table from 2x4's that the dolly sat on top of and raised the motor up to a comfortable height to work on it.
Early on, I ran into a problem that the nut on the crankshaft pulley needs a bigger and deeper socket than I could find locally. It's 46 mm if I remember right. I ordered it from Amazon, and waited a few days for it to arrive. Once I had it, I finished the dismantling in one weekend. I went pretty slowly.
During the assembly, I used a piston ring compressor that I borrowed from my local Autozone. I used copious amounts of assembly lube that I got from Napa store. I repainted the motor after assembly using Hammerite "rusty metal primer" and their "hammer finish" copper/bronze paint, that is pretty close to the original Universal color. Both are brush-on. I have previously used these on an Atomic4 engine with good results. See photos in my album for the finished paint job.
Timeline? - Most of the time seemed to be spent waiting for parts to arrive.
I pulled the motor in late June (2013) and started dismantling.
The machine shop took maybe three weeks. Carl was pretty conservative, he would not machine something until he had the new parts in hand and would measure them before machining the old ones. We rejected one set of new bearings that were right on the limit of the tolerance spec and had to wait again for a new set to arrive before proceeding.
Assembly took two weekends, and a few hours during the week. Again, I went slowly. At the end of the reassembly, I set up a test rig and ran the motor for maybe 3 hours.
While waiting on parts etc I also did some work on the engine bay - pulled the fuel tank and flushed it out completely. Painted the engine bay with Interlux 2000, ran new fuel hose and installed a new electric lift pump for the fuel. Reinstalled the tank before the engine (it sits behind the engine in my boat).
Reinstalled engine in early September. My marina has a hand-operated chain hoist that slides along a 10 foot beam, mounted 15 feet above the water on a post that allows it to rotate 360 degrees. It's intended as a mast hoist, but works great for pulling and installing engines too.
I don't have a really exact handle on the hours I spent. Probably 2 weekends each for dismantle and assembly. Plus a few evenings. One day each for removal and re-installation. A few lunchtimes running back and forth to Kubota dealer to order and pick up parts, and to visit the machine shop to drop parts off. Online searching and ordering, maybe a few more evenings.
Happy Thanksgiving!
Eric
Eric Irvine
1980 Bristol 29.9
Selkie
post #15 of 17 Old 11-30-2013 Thread Starter
davidpm's Avatar
Eric
That is something I wouldn't have thought of.
Thanks for all of your answers.
Your project is an inspiration that it can be done.
If you don't mind and can find that video post it on youtube.com and link to it here.
It would be a great wrap-up.
Any pictures would be great too.
I find posting them imgur.com and inserting a link the best way to do pictures here.
post #16 of 17 Old 12-14-2015
midwesterner's Avatar
Hi David
Happy Thanksgiving!
Eric
Thanks for sharing your experience. I'm presently looking at older used boats that fit my limited price range. I'm considering some lower priced boats and figuring the price of repowering into the cost of the boat.
Did you have any problem finding the correct oversized crankshaft bearings once the machine work was done? Were the parts readily available? You mentioned that the first bearings you bought were just barely within specs and you had to re-order. How were the Kabota parts people to deal with?
Thanks,
Bill
midwesterner is online now
post #17 of 17 Old 02-25-2016
ericirvine's Avatar
Bill,
I'm very sorry to take so long to reply. I ordered some parts from my local Kubota dealer, and others from an online Kubota parts source. Both were very helpful and easy to work with. The parts diagrams on the Kubota website were very helpful for figuring out correct part numbers, see my other posts for instructions to get these. Going to my local dealer was helpful as I could talk with the mechanics (they actually referred me to the machine shop I used). Online shopping was sometimes quicker and sometimes cheaper.
HTH,
Eric
Eric Irvine
1980 Bristol 29.9
Selkie
$6,600 to rebuild Atomic 4? replace/rebuild simmonct Atomic 4 73 03-13-2017 11:49 AM
Alternator for Universal 5416 Romario Diesel 19 08-19-2015 03:55 PM
Starter for Universal 5416 jimgo Diesel 16 03-26-2013 10:00 AM
Universal 5416 filters deniseO30 Gear & Maintenance 3 05-05-2009 10:50 AM
zinc in Universal 5416? wumhenry Gear & Maintenance 12 05-16-2007 04:01 PM
