Yanmar loses RPM in gear - Page 3 - SailNet Community
Chat
Advertise Here
Go Back   SailNet Community > On Board > Gear & Maintenance > Engines > Diesel
Old 11-30-2013
shansen5 is on a distinguished road
Re: Yanmar loses RPM in gear
Originally Posted by mitiempo View Post
Either a Yanmar dealer or one can be fabricated - either welded or from black iron plumbing parts. Stay away from galvanized as it can give off noxious fumes if it ever gets hot enough.
I saw one fabricated on another thread. That looked like fun, so I may try it, since it is a few months until I'll be going anyplace substantial.
Custom Exhaust Riser/Mixing Elbow | s/v Smitty
Different engine and 1 1/2 inch where mine is 2 inch.
(What a great forum this is!)
Steve
Reply With Quote Quick reply to this message Share with Facebook
  #22
Old 01-30-2014
tomharry is on a distinguished road
Hi
yanmar 1gm,motored up river for 1hr all good,following weekend would not start.
have had injector cleaned,fitted new head casket as oil was grey,now changed oil/filter.fuel filter primary and secondary changed.water pump hoses clamps all changed.motor will not start when does need full throttle and then it slow builds revs,knock throttle back and it stops.cleaned elbow.
is this a fuel pump problem?or rings gone on piston?
thank you paul
  #23
Old 02-03-2014
hi all update on my bl!@dy yanmar.can confirm it is the injector pump and motor is out of yacht and at home.just secured another yanmar for $700nz which has been rebuilt new piston rings injector pump.heard it running with a diesil mechanic and his advice grab it.
tomharry
6:14 PM
now will fit my new starter and alternator,new mounts,will change oil/fuel f
Tags
rpm loss , yanmar
You may post attachments
You may edit your posts
Yanmar 2gm20f RPM RobGallagher Diesel 2 06-30-2012 04:24 PM
Yanmar 2GM20F RPM issue cspaniel Diesel 11 05-20-2012 05:01 PM
Yanmar not making RPM Flyyboy Diesel 18 12-26-2009 11:32 AM
more RPM issues - yanmar rperret Gear & Maintenance 5 10-19-2008 08:51 PM
Copyright ©2000 - 2015, vBulletin Solutions, Inc.
SEO by vBSEO 3.6.1
The SailNet.com store is owned and operated by a company independent of the SailNet.com forum. You are now leaving the SailNet forum. Click OK to continue or Cancel to return to the SailNet forum.
