Fuel pump time on Yamnar SB8 - SailNet Community
post #1 of 2 Old 11-29-2013 Thread Starter
Angry Fuel pump timing on Yamnar SB8
Hi,
I installed a new high pressure fuel pump on Yanmar SB8 engine. No fuel comes out of it. One of the previous threads talks about fuel pump timing. How do I do it? and is it the cause of my problems?
I did bleed the air out of the line. Any help would be greatly appreciated.
First timer is offline
post #2 of 2 Old 11-29-2013
Re: Fuel pump time on Yamnar SB8
This may help...
http://www.yanmarmarine.co.uk/pdfs/o...al/B0A1669.pdf
.. or not.
Fuel pump timing is pretty critical.. if the motor didn't 'move' during install and you engaged any gears the same way it came out you should be OK.. tough to know, though...
No throughput at all sounds like there's still air in the system.
And there's this:
http://www.justanswer.com/sip/yanmar...FWRBQgodXV4A8A
Faster is online now
Tags
fuel pump timing , yanmar sb8 engine
Fuel Pump HorizonHunter Atomic 4 4 08-05-2010 04:50 PM
Fuel Pump puff6022 Gear & Maintenance 4 11-28-2008 04:07 PM
Help, pump not getting fuel! MedSailor Gear & Maintenance 16 07-10-2008 09:02 PM
recirculating fuel pump mpraca Gear & Maintenance 24 07-05-2007 09:56 PM
Fuel pump justified Gear & Maintenance 5 06-18-2007 07:25 PM
