particulate residue in Racor bowl - Page 2 - SailNet Community
post #11 of 12 Old 12-06-2013
TomMaine's Avatar
Re: particulate residue in Racor bowl
Originally Posted by grandcapri View Post
ANYONE? ANYONE?......{crickets}
Sounds normal to me. There's always a little sediment in the bottom of the bowl on my racor when I change the filter( I don't drain it between changes, no water seen). The bowl is on the other side of the filter path.
If you don't have fuel problems and changing your filters regularly, I say your fuel system is doing what it's designed to do.
Tom Young sailing a 1961 38' Alden Challenger, CHRISTMAS out of
Rockport, Maine.
'I'd have written a shorter post, but I didn't have the time', Mark Twain.
TomMaine is offline
post #12 of 12 Old 12-06-2013
DrB
Diesel Fuel Source
Since we use very small amounts of fuel a year, < 10 gal/season, I bought a 5 gal diesel tank and buy my diesel at an interstate truck stop. I fill up at the end of the season, then refilll and top it off at the end of the season before winter storage. I have a 20 gal tank. I add a little biocide at each fill.
Had the boat for 7 years, never had an issue with water, bugs, or junk. Each time I change my Racor filter, I do see some residue film on the sides of separator bowl, but never water.
If you liked my advice/response, give me some rep points. If you didn't......well what do you expect, it was free.
DrB is offline
Particulate residue in Racor bowl grandcapri Gear & Maintenance 0 12-02-2013 08:25 PM
Clean up the residue from butyl rubber? Hudsonian Gear & Maintenance 5 04-17-2012 02:11 PM
remove 3M tape residue from topsides & interprotect gallilaw Gear & Maintenance 15 05-16-2011 02:02 PM
Why is there white residue on my deck? saurav16 Gear & Maintenance 5 05-25-2008 07:07 PM
How to Remove nasty glue residue from headliner? gratefulsailor19 Gear & Maintenance 4 02-07-2007 12:26 PM
