Universal Instrument Panel - SailNet Community
 1Likes
  • 1 Post By eherlihy
post #1 of 9 Old 12-04-2013 Thread Starter
I need some advise on why my Instrument Panel is not working properly please. I have a 1999 Universal Diesel Engine (M-25XP) with an instrument panel which was likely installed at the same time.
I've had the boat 6 yrs. and do most maint. myself, with a few projects left to the pros.
This past year my engine appeared to be running very well, but the instrument panel is not working correctly- all of the guages bounce around when at idle and also while in gear.
I've checked all connections at they "appear" to be connected...
Maybe a short in one of the wire connectors?
Any thoughts?
Any direction is greatly appreciated!
Lisa
CaptLDL is offline
post #2 of 9 Old 12-04-2013
azguy's Avatar
Re: Universal Instrument Panel
At least in cars and motorcycles that happens when you have a bad ground.
1988 C22 Owner
azguy is offline
post #3 of 9 Old 12-04-2013
Learning the HARD way...
eherlihy's Avatar
It is likely that you either have a bad ground, or bad connection on the +12VDC side of the gauge.
The FIRST thing that I would do is to verify that the old, "plug-style" connection to the gauges has been retro fitted to the newer, "screw-type". See http://www.catalina30.com/techlib/wi...deInfoPkg1.pdf and this; http://forums.catalina.sailboatowner...d.php?t=135558
If that is OK, then I would take an Ohm meter, and test for continuity to the ground (black [likely], or yellow[less likely]) connection at the rear of the panel, by shaking the wire. If this works, shake the wire at the harness connector, and again near where it ties into the ground for the boat. I'd do the same with the +12V (Red) wire, testing for continuity between the 12V breaker that powers the instruments.
eherlihy is online now
post #4 of 9 Old 12-04-2013
eherlihy's Avatar
Oh; PLEASE tell me that you do not have an AMP meter in your panel...
post #5 of 9 Old 12-06-2013 Thread Starter
Thanks everyone. I will check on these things next visit to the boat.
Honestly I'm not sure what I have/don't have...
CaptLDL is offline
post #6 of 9 Old 12-06-2013
The problem with the ammeter is, if the charging current from the alternator is passing through it, you tend to lose a lot of charging efficiency. On my Universal 5424, there is a direct wire from the alternator to the battery switch, so the ammeter reads nothing when running as all the charging current is bypassing it.
MarkSF is offline
post #7 of 9 Old 12-06-2013
Trailer connector in the wiring harness leading from the engine to the pannel?
snotter is offline
post #8 of 9 Old 12-06-2013
eherlihy's Avatar
Follow the link in my earlier post. This is how Universal made for a quick connect harness. The problem is that these connectors would oxidize, as current would pass through the increased resistance from the oxidized connector, it would generate heat, and MELT THE CONNECTOR...
This is a serious problem with the old instrument panels that had an Amp meter, because rather than using a shunt, the 51 Amp output from the alternator ran directly to the meter through two of these crappy connectors.
CaptLDL likes this.
post #9 of 9 Old 12-08-2013
I had a similar issue with the fuel gage. I pulled the panel to install a new tach and found a few loose connections. Cleaned and tightened. All is well now.
H and E is offline
Replacement Engine Instrument Panel Lucky dog 2 Atomic 4 1 07-16-2012 12:00 PM
Instrument panel came right out zAr Gear & Maintenance 9 07-13-2012 09:50 PM
Parts for Wauquiez instrument panel talley Wauquiez 3 09-23-2011 04:40 PM
Galley instrument panel brokesailor Pacific Seacraft 14 06-23-2011 03:44 PM
The new instrument panel tommays Cal 0 04-30-2011 06:47 PM
