Perkins 4.108, Stop solenoid failure - SailNet Community
post #1 of 12 Old 12-08-2013 Thread Starter
Could anyone advise how to stop a Perkins 4.108 in the event of a stop solenoid failure. As far as I can see there is no mention of how to do this in the owners manual. Thankyou
jamesjle is offline
post #2 of 12 Old 12-08-2013
Re: Perkins 4.108, Stop solenoid failure
You could turn your fuel tap off,
harmonic is offline
post #3 of 12 Old 12-08-2013
Dirt Free
boatpoker's Avatar
Just push the solenoid in by hand.
Be the man Sharon thinks I am - wg
I can do that
- wg
Be the master of your own disaster - wg
If you're not laughing, you're not doing it right. - wg
if you can live with the consequences, go for it. - wg
I yam what I yam an' thats all that I yam. - Popeye
boatpoker is offline
post #4 of 12 Old 12-08-2013
Old as Dirt!
svHyLyte's Avatar
The Stop Solenoid activates a small push/pull rod on the back of the injection pump that when pulled out somewhat, cuts of the fuel. The injection pump on the 4-108 is on the port side of the engine (in our case) directly below the heat exchanger and can be a little awkward to reach but one needs only two fingers to move the rod an inch or so. If you are worried about the need, I suggest you try it once of twice so that you know how to do it when it might become necessary.
FWIW...
svHyLyte is offline
The Following User Says Thank You to svHyLyte For This Useful Post:
jamesjle (12-08-2013)
post #5 of 12 Old 12-08-2013
I'm having intermittent problems with mine. It's a Perkins 4-154 I tied a small line to the shutdown lever the solenoid pulls. When the electric doesn't work I can just open the engine room door where I tied the other end of the line and pull. This is/was a end of season "fix". My boat still has the pull cable fitting on the pedestal. I plan to go back to a cable system. Don't see a need to make a simple system complicated by making it electrical.
ctl411 is offline
The Following User Says Thank You to ctl411 For This Useful Post:
post #6 of 12 Old 12-08-2013
Couldn't you block the air intake?
Hudsonian is offline
post #7 of 12 Old 12-08-2013
Sea Sprite 23 #110 (20)
mad_machine's Avatar
big heavy rag over the intake works wonders.. or a plate, or anything that will stop airflow without damaging the engine or you (I don't recommend your hand, just incase you get a backfire)
Art Haberland
In the end all that matters is how fully you loved, how gently you lived, and how gracefully you let go of things that did not belong to you -Buddha
mad_machine is offline
post #8 of 12 Old 12-08-2013
I did use a plate over the intake the first time. I wouldn't use my hand, bad idea not because of back fire but blood blister from the vacuum. I had heavy equipment buddys at Ferris State University tell me about a runaway diesel. It ate a 3/4 plywood board the used to try to stop it.
ctl411 is offline
post #9 of 12 Old 12-08-2013
poopdeckpappy's Avatar
Ive had two go south on me, Im going with a manual pull back by the helm; Until I do that, I use the method Hylyte mentioned, it' pretty easy access and it don't much movement
1955 Blanchard 51 Custom ( I got a woody )
1974 Ranger 33
Friends don't let friends do stupid things alone
poopdeckpappy is offline
post #10 of 12 Old 12-08-2013
aeventyr60's Avatar
You may want to take a look at the spring that holds the lever in place, a good spare to have...
The mushroom cap/vent on/over the intake makes it hard to get at, think a rag would have to do the job
"Your dreams minus your doubts equals your net worth"
Life is a short journey, filled with emptiness and pain. Get all the sailing and booty you can.
aeventyr60 is offline
Old Perkins 4-108 firemanbob Living Aboard 5 08-15-2015 04:06 PM
diesel stop solenoid dreamer2010 Diesel 11 03-24-2012 08:20 AM
Stop Solenoid & Alt questions poopdeckpappy Electrical Systems 9 08-26-2009 01:36 AM
Perkins 4-108 bnskramer Gear & Maintenance 9 05-27-2008 07:37 PM
Perkins 4-108 Geoffrey154 Gear & Maintenance 1 10-27-2002 07:01 PM
