Fuel System and ABYC Standards - Page 2 - SailNet Community
post #11 of 19 Old 12-09-2013
Re: Fuel System and ABYC Standards
Originally Posted by miatapaul View Post
I don't think it makes the boat illegal to operate as ABYC is not a legal requirement though your insurance company would likely be unhappily. Many insurance policies require meeting ABYC for modifications and might ask for some systems to be brought up to the standard though some may not.
Sent from my ADR6425LVW using Tapatalk
See... 46 CRF 182.130 below. This applies to non-commercial small boats as well as commercial. Though inspection isn't required.
Title 46: Shipping
CHAPTER I: COAST GUARD, DEPARTMENT OF HOMELAND SECURITY (CONTINUED)
SUBCHAPTER T: SMALL PASSENGER VESSELS (UNDER 100 GROSS TONS)
PART 182: MACHINERY INSTALLATION
Subpart A: General Provisions
182.130 - Alternative standards.
As an alternative to complying with the provisions of this part, a vessel of not more than 19.8 meters (65 feet) in length, carrying not more than 12 passengers, and propelled by gasoline or diesel internal combustion engines, other than a High Speed Craft, may comply with ABYC H-2, ABYC H-22, ABYC H-24, ABYC H-25, ABYC H-32, ABYC H-33, ABYC P-1, and ABYC P-4 (all eight standards incorporated by reference, see 46 CFR 175.600) as specified in this part.
[USCG-2003-16630, 73 FR 65207, Oct. 31, 2008]
Greg
Stumble is offline
post #12 of 19 Old 12-10-2013
For what it's worth I finally got a reply from someone who was on the ABYC fuel system committee from the mid 90's to 2004. His reply was basically that the USCG prohibited stainless years ago in keeping with ABYC requirements. Once the USCG adopted the rules it has become almost impossible to change them, since the ABYC cannot permit that which the law prohibits.
Apparently rewriting this was looked at, but there were still not a consensus that stainless as a fuel line was safe, due to concerns over crevice corrosion, work hardening, cracking at the fittings, and galvanic corrosion. Though there seems to be plenty of evidence these concerns are minor.
In short, there doesn't seen to be a clear engineering prohibition, just a legal one. But that legal one does effect recreational boats.
Greg
Stumble is offline
post #13 of 19 Old 12-11-2013 Thread Starter
Thanks for your time and effort in tracking down this info.
Are you able to provide a little more insight and explanation into the whole sub system point you made? With the filterboss, the filters are used as your primary filters, so it is very much a part of the regular fuel route. But it can also be used as a polishing system.
Cheers
nsweeting is offline
post #14 of 19 Old 12-11-2013
Basically this rule only effects the delivery lines. But it doesn't effect fittings, or subsystems. So from the tank to the racor, from the racor to the engine, and any transfer lines between tanks. Once it gets to the engine you can use stainless, fittings, high preasure lines, ect.
Greg
Stumble is offline
post #15 of 19 Old 12-11-2013 Thread Starter
Just to clarify -
I was reviewing the USCG Boatbuilders Hanbook which references Title 33 CFR Part 183 Subpart J for its fuel requirements. The very first line mentions that these are the requirements for gasoline powered inboards. So am I to understand the rule regarding the fuel lines does not apply to our diesel engines then?
First sentence in the below link:
Fuel Systems - Introduction
Edit:
I also found the actual regulation which also states the laws are applicable to gas inboards - under the Applicability section.
http://law.justia.com/cfr/title33/33...:2.0.1.8.44.10
post #16 of 19 Old 12-11-2013
183 is a standard for gas engines
182 incorporates the ABYC rules.
Greg
Stumble is offline
post #17 of 19 Old 12-11-2013
My limited understanding is that the sulphur traditionally found in diesel fuels, attacks stainless steel and makes stainless unsuitable for diesel systems.
Granted that two "new" reductions in sulphur content have happened in recent times, it is possible that the recommendation excluding stainless is just a legacy issue and now a moot point for US vessels.
I don't see work hardening as being an issue, that affects copper lines much more than stainless, and is the reason why copper lines are forbidden in automotive brake systems--where stainless is the standard metal, constantly being hit by expansions and still not work hardening at all.
hellosailor is offline
post #18 of 19 Old 12-17-2013
I have seen several sources indicating that one should not allow copper, zink or any compound containing them (brass) to come into contact with diesel.
If this is correct, how does this affect the fuel system standards being quoted in this thread when one is operating with diesel as a fuel?
I have some brass fittings in my diesel fuel system and always wonder if I'm hurting my engine. Not so far.
Any comments?
FiveFilter is offline
post #19 of 19 Old 12-17-2013
mitiempo's Avatar
Brass is ok as far as I know but do not attach brass fittings to an aluminum tank.
Brian
mitiempo is online now
Air in fuel system Romario Diesel 18 09-16-2013 11:02 AM
2QM15 Fuel System Need Help Lanky55 General Discussion (sailing related) 7 09-10-2012 12:44 PM
2QM15 Fuel System Need Help Lanky55 Gear & Maintenance 0 09-07-2012 12:20 PM
fuel filter system.. groundhog Gear & Maintenance 7 08-20-2008 12:14 PM
Scott Stephens does ABYC proud - 2006 Optimist Selections - Day 7, the FINAL Day @ ABYC, Port Elizabeth, South Africa NewsReader News Feeds 0 04-13-2006 07:15 AM
