buying a used yanmar 2qm15, TIPS? - SailNet Community
 2Likes
  • 1 Post By fryewe
  • 1 Post By sony2000
post #1 of 7 Old 12-22-2013 Thread Starter
christian.hess's Avatar
any real life pointers on SPECIFICS before going ahead would be greatly appreciated
stuff like
where does corrosion start and what gets destroyed first? elbow, pan, etc...
whats a solid cruising rpm(propeller pitch and diameter)
what to look at when buying used...
can you do an easy compression check on it? does it have decomp levers like the 2gmf?
I should add that Im not completely unfamiliar with this type of engine as I had a freshwater 2gmf that I travelled with for 12k milles and became completely familiar with it
however it does have some differences that might not translate to the 2qm
thanks
christian.hess is offline
post #2 of 7 Old 12-25-2013 Thread Starter
Re: buying a used yanmar 2qm15, TIPS?
anybody rebuilt one lately or bought one lately? any experience welcome!
thanks guys
merry christmas
Merit 25 sold...Islander 36 still afloat? who knows...Im still in Columbus, and back...I think...jajajaja!!!!
post #3 of 7 Old 12-25-2013
fryewe's Avatar
Congratulations on your dadship. Nothing better.
I have two 2QM15s...owned one since '83 and the other I bought in '07 as a garage queen spare parts engine since the age of the QMs means some parts are hard to come by.
When I bought a salvaged boat in '10 that needed an engine I restored the garage queen for the second boat rather than invest in a new one.
The failures I have had are in the cooling and exhaust systems. I had to have an exhaust manifold soldered due to a crack (no new ones available). I had to replace exhaust elbows on both. I had to rebuild a worn out water pump. I had to have an alternator rebuilt. I had to replace the injection pump on one engine but that was my fault because I let it sit idle for too long and it got a little rust on it where clearances were important. Exhaust elbows are available but the only sources of some major parts like the manifold or water pump are to fabricate them or find one on a salvageable engine that is still serviceable.
Mine have been good engines for the 4-5 ton boats I have pushed with them. They sip fuel while cruising at about 2100RPM - about a pint and a half an hour at five knots or so in relatively calm conditions.
Look for cracking in the exhaust elbow. Also the raw water cooled manifold will plug with exhaust/salt/metal deposits and may require cleaning using muriatic acid and a relatively long stiff prod to work on the hard deposits. If hoses haven't been replaced in some time you will likely need to replace them. Check to see if zincs still have active material to determine if they have been routinely replaced...if so the corrosion will probably be limited. The engine does have decompression levers.
These engines were built in the mid seventies (almost 40 years old!!) so when I saw parts becoming limited several years ago I bought parts and gaskets needed for most repairs except pistons/rings/cylinders. All the gaskets and hoses were available then but seem to be getting harder to find. You will certainly need the gaskets for pulling and replacing the exhaust manifold and elbow.
When I bought the garage queen engine it had been removed from a boat due to overheating and a head gasket leaking water into the engine room. I brought it home and built wooden rails for the mounts and hooked up cooling water and a battery and primed the fuel system using a portable tank and squeeze bulb. It started after a couple of revolutions. If the engine you are looking at has no known problems you should be able to do the same. If not...you should be very skeptical about its condition.
I got the engine for 400USD and put about 800USD into reconditioning it not including engine controls and cables/new motor mounts/electric panel and wiring/muffler/exhaust hose/bronze exhaust fittings. These support systems cost almost about another 1200USD. I did most of the installation including engine beds so was able to keep the cost down but you have to understand the support systems are VERY expensive...especially exhaust hose and fittings and motor mounts.
Talk to the folks at West by North (or see their website) about a Campbell Sailer prop for the engine/boat combo you have. They can hook you up...for another 500 or so.
Good luck.
christian.hess likes this.
The web makes everywhere the same place. - Fred Reed, from "Fred on Everything"
fryewe is offline
The Following User Says Thank You to fryewe For This Useful Post:
christian.hess (12-25-2013)
post #4 of 7 Old 12-25-2013 Thread Starter
thats about all I need to really know
thanks man
merru christmas
PS. im checking out the engine tomorrow....hopefully shell start
post #5 of 7 Old 12-26-2013 Thread Starter
well unfortunately the test and view did not go well
both the tranny(kanzaki I beleive) and bottom of the belly or pan were completely corroded, so much so that oil oozed out the bottom of the engine
sooooooooo I see you can replace the pan but the bottom of the tranny is going to be tough....thats kind of a deal killer right there
soo Im back to square 1 unless this guys wants to give it away which he does not
cheers
post #6 of 7 Old 01-03-2014
The cheapest Jackplate raises and lowers about 10", and will handle a 20hp outboard. Setting the engine at 3000 rpm could prevent it from going over 4500 rpm when riding a swell. Better luck next time!
sony2000 is offline
post #7 of 7 Old 01-04-2014 Thread Starter
thanks sony
for those interested in how to fix something like this this is my inquiring thread regarding corroded pans and bottoms...
http://www.sailnet.com/forums/diesel...an-yanmar.html
thanks
2QM15 Yanmar weephee Gear & Maintenance 5 04-06-2013 09:15 PM
Yanmar 2QM15 sundownersc Diesel 11 02-09-2012 10:21 AM
Yanmar 2QM15 repairtime Gear & Maintenance 7 12-09-2011 05:40 AM
Yanmar 2QM15 Zinc(s) backcreeksailor Gear & Maintenance 9 05-30-2009 08:48 AM
Yanmar 2QM15 rpowell Gear & Maintenance 3 01-10-2002 09:26 PM
