Diesel or noises - SailNet Community
post #1 of 8 Old 12-27-2013 Thread Starter
PIP
Diesel or noises
I have a 12 month old beneteau and it has started to make knocking noises when the motor is off and we are cruising. This stops when I put the throttle into reverse. ANy ideas on what this could be ????
PIP is offline
post #2 of 8 Old 12-27-2013
Re: Diesel or noises
Sounds like your prop is spinning.. what engine, transmission and prop do you have?
Faster is offline
post #3 of 8 Old 12-27-2013 Thread Starter
PIP
29hp Yanmar
PIP is offline
post #4 of 8 Old 12-27-2013
islander bahama 24
newhaul's Avatar
It depends on the transmission in gear while sailing with the kanzaki tranny would void the warranty but in gear with the hurth is actually recommended by manufacturer. Refer to manufacturers advisory # msa08-003
Illegitimus Non Tatum Carborundum.
newhaul is offline
post #5 of 8 Old 12-27-2013
Dog Ship's Avatar
Our 3gm30f Yanmar/Kansaki combo does that too.
As soon as the prop starts to turn at about 4 knots it makes a noise.
It sounds like a heavy piece of metal running over a cam and hitting the prop shaft. It's rather annoying but it doesn't do it all the time.
I talked to the local Yanmar dealer and they said it is was a common thing??? and if you don't like it you could put a shaft brake on it.
I had forgotten about it as it hasn't done it in quite some time.
We have three rules;
No screaming.
No bleeding on the sails.
No slobbering on the charts.
Dog Ship is offline
post #6 of 8 Old 12-27-2013
trantor12020's Avatar
Put it in reverse to stop prop spinning. Wont hurt kanzaki gear box.
Ken
2002 Hunter 326, SV Millennium 2
1999 Macgregor 26X, SV Millennium
trantor12020 is offline
post #7 of 8 Old 12-27-2013
Cruising at a snail pace
did you check the oil level in the transmission?
Don't blow air up my rear, be useful and blow it at the sails!
Don0190 is offline
post #8 of 8 Old 12-27-2013
Dog Ship's Avatar
That was my first thought when I heard this noise but the oil level was good and I have had the oil changed twice in the two and a half years we have owned the boat.
I haven't heard this noise in quite some time now. It does make me feel better that someone else has heard this noise though.
No screaming.
Dog Ship is offline
Strange noises from below... Dave Montgomery General Discussion (sailing related) 13 05-02-2013 04:20 PM
Diesel fuel lines -Universal 3cyl diesel argofred Diesel 8 04-18-2011 03:39 PM
Engine noises brak Gear & Maintenance 4 05-20-2009 02:45 PM
Auto Diesel vs Marine Diesel / Addatives NewsReader Mass Bay Sailors 0 07-11-2007 06:15 PM
Ultra low sulphur diesel and the older marine diesel Valiente Gear & Maintenance 2 10-20-2006 12:10 PM
