Yanmar 2QM20 Thermostat swap - SailNet Community
post #1 of 6 Old 12-30-2013 Thread Starter
I have a 2QM20 that was switched over to FWC from Raw Cooled. My problem is that my thermostat appears to be the original and opens at 120 degrees. I would like to get the temp higher by putting a higher opening temp thermostat. Does anyone know if there is a thermostat I can swap out or am I just stuck with the original? It seems to have been this way for years. Thanks.
Froggy is offline
post #2 of 6 Old 12-30-2013
mitiempo's Avatar
Re: Yanmar 2QM20 Thermostat swap
Should be one. The fresh water cooled Yanmars have the same thermostat housing I believe. Check with a Yanmar dealer.
Brian
mitiempo is offline
post #3 of 6 Old 12-31-2013
Mechsmith
Take old thermostat to an auto parts store and match one up. Shouldn't be a problem.
Seafarer 29 KCB
Mechsmith is offline
post #4 of 6 Old 01-01-2014
Liquorice's Avatar
Checking the manual here:
http://www.dieselpartseurope.com/web...vicemanual.pdf
Raw water thermostat opens at 41deg C / fresh water thermostat opens at 72degC.
So yes there is an alternative thermostat.
sam :-)
Just because you're paranoid ...doesn't mean they're not after you!
Liquorice is offline
post #5 of 6 Old 01-01-2014
mitiempo's Avatar
As posted any auto parts store should have one. No reason to pay Yanmar prices for an item they don't make anyway.
Brian
mitiempo is offline
post #6 of 6 Old 01-01-2014
RichH's Avatar
Heres a source for a FWC thermostat for your 2QM. http://www.marinedieseldirect.com/ya.../thermostat.ph
Yanmar uses 'wax filled' T'stats unlike 'automotive' T'stats which use a 'bi-metalic spring' system. The 2QM and 3QM T'stat for raw cooled opens fully at about 120F, the FWC opens fully at ~160F.
RichH is offline
Winterizing a Yanmar 2QM20 rikhall Diesel 3 11-23-2013 11:03 PM
Oil Filter Yanmar 2qm20 Froggy Diesel 3 10-01-2013 06:19 PM
Yanmar 2QM20 Exhaust part - help hertfordnc Gear & Maintenance 19 12-13-2010 06:07 PM
Yanmar 2qm20 oil out breather Gerrit747 Diesel 4 09-24-2010 06:25 PM
