Yanmar 3gm30f Fuel injection limiter - SailNet Community
post #1 of 5 Old 01-01-2014 Thread Starter
Has anyone experience with a leaking fuel injection limiter ? Is there a gasket that needs to be replaced ?
carlager is offline
post #2 of 5 Old 01-01-2014
aa3jy is offline
post #3 of 5 Old 01-03-2014
trantor12020's Avatar
Re: Yanmar 3gm30f Fuel injection limiter
I don't think that red circle part is the fuel limiter. Its the hand crank shaft. Open the cap, ply out the oil seal with a flat blade screw driver and go buy a replacement. Probably a $2 fix.
Ken
2002 Hunter 326, SV Millennium 2
1999 Macgregor 26X, SV Millennium
trantor12020 is offline
The Following User Says Thank You to trantor12020 For This Useful Post:
carlager (01-03-2014)
post #4 of 5 Old 01-03-2014 Thread Starter
Trantor.
I think you are right. Is the hand crack shaft for starting the engine manually ?
carlager is offline
post #5 of 5 Old 01-03-2014
Yes. I've mod mine for hand crank. NEVER EVER got it to start by manual cranking. Took it off. Suggest you ply out the oil seal and take it to an auto shop to get a new one. If you got one that is a wee bit thicker but the OD and ID is same, it'll work too.
Ken
carlager (01-04-2014)
Secondary fuel filter yanmar 3gm30f carlager Beneteau 2 07-25-2013 07:23 PM
Yanmar YSE 8 fuel injection issue? sadie anne clawe Diesel 12 04-26-2013 12:49 AM
Yanmar 3GM30F Primary fuel filter thaeni Diesel 3 08-10-2010 12:00 PM
Fuel filter replacement on Yanmar 3GM30F gsyversen Gear & Maintenance 7 06-13-2008 02:18 AM
Yanmar - fuel injection pump question rperret Gear & Maintenance 7 05-24-2007 10:00 AM
