Yanmar 1GM10 runaway? - Page 3 - SailNet Community
 8Likes
post #21 of 80 Old 01-12-2014 Thread Starter
Remember you're a womble
PaulinVictoria's Avatar
Re: Yanmar 1GM10 runaway?
It'll probably run out of oil now.
Orange Crush
1974 C&C27 MkII
PaulinVictoria is offline
post #22 of 80 Old 01-12-2014 Thread Starter
It's odd though, I'm sure the level has gone up, I can't imagine I misread it consistently. Absent any diesel, the only other place that contains anything fluidy is the transmission.
Orange Crush
1974 C&C27 MkII
post #23 of 80 Old 01-12-2014 Thread Starter
Oh and I forgot to say, it was maybe 1/4" above the max line.
Orange Crush
1974 C&C27 MkII
post #24 of 80 Old 01-12-2014
Courtney the Dancer
jrd22's Avatar
Paul- I would suggest an oil analysis. It's possible that you are getting diesel into the lube oil, there aren't too many other ways that the level can go up. You might be able to tell if it's diesel contamination by the feel test, suck some oil out of the engine and compare to fresh oil between your fingers.
John
SV Laurie Anne
1988 Brewer 40 Pilothouse
jrd22 is offline
post #25 of 80 Old 01-13-2014 Thread Starter
I'll do a quick paper check next time I'm at the boat.
Orange Crush
1974 C&C27 MkII
post #26 of 80 Old 01-13-2014 Thread Starter
Well, I tried the paper test on the oil, it looked pretty much like number 2 on this diagram, oily coloured blob with a very slight clear edge which would indicate a lack of diesel in the oil.
All very odd, I checked the oil level again and it was where I left it Sunday, about 1/4" below max (looks like had I only taken out about 200ml then it would have been bang on max). Don't know, maybe I had a bit too much oil in there (but not by much) and it just misted that up to the intake which eventually hit the sweet spot for self accelerating behaviour.
Oh well, I think I'll just keep an eye on things and see how it goes.
Orange Crush
1974 C&C27 MkII
post #27 of 80 Old 01-14-2014
Maybe make up something you can easily block off the air flow with, a rag, plug, or plate? I have read a CO2 extinguisher may work?
Maybe wear some body armor & a helmet before going below to fix the runaway?
Paul T
dabnis is offline
post #28 of 80 Old 01-14-2014 Thread Starter
Nice thing about the little Yanmar is there is a decompression lever right on the top within easy reach. The air intake is a little bit tough to get to when the engine is screaming away.
Orange Crush
1974 C&C27 MkII
post #29 of 80 Old 01-14-2014
No hands on experience with Yanmars, but I think I have read not to use the decompression lever(s) to stop the engine, something about the valves?
Paul T
dabnis is offline
post #30 of 80 Old 01-14-2014
Irrationally Exuberant
Yeah, that decompression lever just pushes one of the valves (the exhaust I guess) down a little bit. I can't see trying that while the valve is pounding up and down.
Tom K
2000 Beneteau 331
Northern Chesapeake Bay
arf145 is offline
Yanmar 1GM10 won't start Sometimesbrilliant Gear & Maintenance 16 08-01-2014 06:00 PM
Loss of power on a Yanmar 1GM10? lawsonmitchell Diesel 7 07-31-2014 09:42 PM
Yanmar 1GM10 won't start. lawsonmitchell Diesel 15 08-08-2013 02:43 PM
Runaway Yanmar 2qm15 HELP! miamiz Diesel 41 05-20-2012 09:00 PM
Yanmar 1GM10 Overheating BayLAzr Diesel 8 07-29-2011 02:40 PM
