Transmission removal - Page 2 - SailNet Community
Advertise Here
Go Back   SailNet Community > General Interest Forums > Gear & Maintenance > Engines > Diesel
Diesel This is a new forum dedicated to diesel engines and their applicable accessories.
Like Tree3Likes
Old 01-27-2014
SOVT is on a distinguished road
Re: Transmission removal
Thanks for all the suggestions. I ended up drilling a 2" hole in the adapter plate. The 1/2" steel was loads of fun to cut thru, lots of cutting oil helped . Of course the bolts were safety wired and about 2" below the hole. So, with a custom bent wrench and a long Dremel tool to cut the wire away I got the job done.
The flange was solidly rusted to the transmission shaft so I'm glad I didn't try to force it.
Mike
Rebuilding The S/V Kompira
  #12
Old 01-27-2014
Thanks for the follow-up.... doesn't sound like a lot of fun!
  #13
Old 01-27-2014
I suppose it is some sort of sickness. But I really enjoy the work.
  #14
Old 01-27-2014
newhaul's Avatar
islander bahama 24
newhaul is on a distinguished road
Glad it worked out for you. When reinstalling it use some good marine grease on the pilot shaft like it should have been done by previous installer. Will make it much easier to remove the next time there's an issue.
Illegitimus Non Tatum Carborundum.
  #15
Old 01-27-2014
eherlihy's Avatar
Will work to sail. :-)
eherlihy will become famous soon enough
A better lubricant for this type of application (high pressure, metal to metal, probable moisture, possible high temp) would be molybdenum disulfide grease;
christian.hess likes this.
USCG Licensed OUPV Captain, ASA 101/103/104/105 Certified Instructor - Also certified in Recreational Marine Electrical Systems
  #16
Old 01-27-2014
Isn't "Tef-Gel" another go-to for this sort of thing?
  #17
Old 01-27-2014
newhaul's Avatar
islander bahama 24
Yes it is one of the better go to for this I just didn't went to get to specific is all. people seem to not like when I get specific.
  #18
Old 01-27-2014
eherlihy's Avatar
With all due respect, I disagree.
From TEF-GEL - Ultra safety systems - Home page
1. The function of Tef-Gel in eliminating dissimilar metal corrosion is the elimination of electrolytes from entering the interface of the metallic surfaces. Tef-Gel paste contains 40% PTFE powder and 0% volatile solvents, no silicones or petroleum solvents to evaporate, which would leave voids for electrolytes to be drawn into creating a galvanic cell. When both surfaces are coated and mated with Tef-Gel there are no voids for electrolytes (saltwater) to be drawn in by capillary action over extended periods of time.
2. The function of Tef-Gel in eliminating seizing galling and friction welding of stainless steel, inconel, and other nickel alloys.
I used to use Molly Grease when assembling driveline components on motorcycles. At the time, there was quite a debate about it vs marine grease (much like crimping vs soldering), but the final conclusion is that Molly Grease was the appropriate lube for the conditions stated in my prior post.
Faster and christian.hess like this.
  #19
Old 01-28-2014
Capt Len is on a distinguished road
Now you can move the 2 inch hole to a better location so it will be more useful next time.
  #20
Old 01-30-2014
new dad!
christian.hess is on a distinguished road
good ole moly but I love me some waterproof bearing grease or heavy duty trailer grease
anything is better than nothing
1973 Islander 36 complete restoration under process!
You may post attachments
You may edit your posts
Re: Transmission Removal NewsReader Mass Bay Sailors 0 06-26-2007 05:15 PM
Transmission Removal NewsReader Mass Bay Sailors 0 06-26-2007 03:15 PM
Copyright ©2000 - 2014, vBulletin Solutions, Inc.
SEO by vBSEO 3.6.1
