Transmission removal - SailNet Community
 3Likes
post #1 of 21 Old 01-11-2014 Thread Starter
I am trying to separate a Paragon 23R transmission from a Perkins 4.270 engine. The best I've been able to do is get the adapter plate about 1/4" away from the bell housing. Yes, I've looked very carefully to ensure that there are no bolts still holding things up. Researching the parts manuals and transmission installation guide it seems that the transmission should just slide in and out.
The only thing that I can figure is that the splines are corroded and or seized to the damper plate. Prior to getting more aggressive than I already have I thought I'd ask here to see if anyone else has any suggestions.
Thanks
Mike
Rebuilding The S/V Kompira
SOVT is offline
post #2 of 21 Old 01-11-2014
Re: Transmission removal
Assuming it's similar to this version:
http://www.chriscraft35.com/paragontransmission.pdf
There certainly seems no reason to think that the spline wouldn't just disengage with a good pull aft. I suspect you're right in thinking it's gummed up somehow.
I'd be tempted to insert a couple of wedges into the gap from opposite sides and tap them towards each other as a form of controlled, gentle persuasion..
Faster is offline
post #3 of 21 Old 01-11-2014 Thread Starter
Faster
Thanks for the response. It is the Paragon P200 in the link you posted.
I got pretty aggressive with it this afternoon, no luck. I pulled the starter and think I'm going to squirt a can of PB Plaster in as best as I can. I can't see the splines from the hole but hopefully will get enough PB down there to loosen things up. Not worried about seals being damaged by the PB as I'm doing a complete rebuild of the motor and transmission.
Thanks again
Mike
SOVT is offline
post #4 of 21 Old 01-11-2014
Good luck!
Faster is offline
post #5 of 21 Old 01-12-2014
Mechsmith
I had to cut a hole in the cover housing and take the bolts out of the flywheel on a similar deal. Excessive force will damage the front bearing in some cases. this damage may not show up for a while.
Seafarer 29 KCB
Mechsmith is offline
post #6 of 21 Old 01-12-2014 Thread Starter
Mechsmith
Thats a great idea. Now I just have to figure out what the bolt pattern dimensions are so I know where to drill.
Thanks
Mike
SOVT is offline
post #7 of 21 Old 01-13-2014
Mechsmith
Hopefully you could use a dental mirror or see enough flywheel through the crack that you have to help determine the location of the bolts.
Seafarer 29 KCB
post #8 of 21 Old 01-13-2014 Thread Starter
Thanks for the follow up message.
Mike
SOVT is offline
post #9 of 21 Old 01-13-2014
islander bahama 24
newhaul's Avatar
Are there jacking bolts for the transmission ( bolt holes with threads in them ) if so will take a larger bolt and just tighten them each a little at a time till it pops apart worth a check prior to cutting and drilling.
Illegitimus Non Tatum Carborundum.
newhaul is offline
post #10 of 21 Old 01-14-2014
You say you've got a1/4 inch gap>> If you can slip in a nut at each hole, Screw a longer bolt in thru plate, thru nut and into bell housing, Put a wrench to each nut and walk them out the threaded bolt.Even pressure all around until you can get at the drive plate bolts if it hasn't already popt Personally, I like an access hole in the adapter plate(about 2 in dis)With a cover so to access the bolts . Seen many come lose or snap their heads. Also like the drive plate with the rubber cups to cut down on rattle and make in and out easier.
Capt Len is offline
Re: Transmission Removal NewsReader Mass Bay Sailors 0 06-26-2007 06:15 PM
Transmission Removal NewsReader Mass Bay Sailors 0 06-26-2007 04:15 PM
