Jabsco 3270 Leak Perkins 4-107 - SailNet Community
post #1 of 2 Old 01-15-2014 Thread Starter
There is a steady drip from the raw water pump on my 4-107. It seems to be coming from behind the body, in the shaft area. I suspect the shaft seal or the bearing seal. Has anyone repaired this problem?
WanderingStar is offline
post #2 of 2 Old 01-15-2014
Re: Jabsco 3270 Leak Perkins 4-107
I've replaced the seals on a couple of Jabsco pumps over the years.. fairly simple job, IIRC I used a vise to press the seals in, but it's pretty straightforward, and you can buy the seals separately.
Jabsco Pump Shaft Seal SP2701-21
Faster is offline
The Following User Says Thank You to Faster For This Useful Post:
WanderingStar (01-15-2014)
Perkins 4-107 parts wanted outboundboi Crew Wanted/Available 5 11-08-2012 06:31 PM
Where Can Get Perkins 4-107 Parts? CAPITAINMEMO Diesel 6 03-07-2011 12:54 PM
Perkins 4-107 trecksail Gear & Maintenance 9 02-02-2009 08:35 PM
Perkins 4-107 Zincs Alden68 Gear & Maintenance 0 05-19-2007 08:40 PM
Perkins 4-107 tjkassen Gear & Maintenance 2 11-02-2004 02:38 PM
