To Rebuild or not to Rebuild that is the question - Page 2 - SailNet Community
 11Likes
post #11 of 16 Old 02-14-2014
Senior Moment Member
SloopJonB's Avatar
Re: To Rebuild or not to Rebuild that is the question
At least change all the fluids before going any farther. Overheating cooks engine oil and coolant.
A compression test would be the next step.
Then read Porfin's as yet unfinished thread about re-building his 4108.
If a fresh engine is needed, definitely rebuild it - a swap is a huge job and will cost WAY more than the already shocking cost of a new crate engine - 30%-50% more if you do everything yourself, probably double if you just write cheques. Either way a new crate engine, installed, will cost as much or more than your boat is worth.
SloopJonB is offline
post #12 of 16 Old 02-14-2014
snake charmer, cat herder
zeehag's Avatar
monitor exhaust for color and consistency. first change oil and see if there is any metal in the oil pan...
formosa 41, cruising tropics
zeehag is offline
post #13 of 16 Old 02-14-2014
Newhaul hit it on the crank. Compression test cold and hot. Diesels are almost like gass just higher compression. Every engine needs oil pressure and temp sensors. If you haven't changed the oil you can do an oil analisis. As you can see I can not spell.
newhaul likes this.
Zen is a matter of recognizing reality.
desert rat is offline
post #14 of 16 Old 02-14-2014
Old enough to know better
I agree with all here, that if there are issues with the motor rebuild it. I think if you can take apart an A4 you should be able to tackle this. A little more complicated but not much. But only worry about it if you have real trouble. compression test, and you might want to have the oil analyzed. (I have used Blackstone, they give a nice summery of the results but there are others) While it may not tell you much about if it is good, it will give you a baseline to start from to watch levels of metals and what not.
miatapaul is offline
post #15 of 16 Old 02-14-2014
An oil analysis may show any abnormalities, but it may be difficult to know if they are caused by short term or long tern problems. As mentioned, a compression test may show which cylinder, if any has a problem. The "miss" may be caused by a bad injector, perhaps damaged by the heat? If you are not losing coolant or oil and it runs OK, you may be lucky?
Paul T
dabnis is offline
post #16 of 16 Old 02-20-2014
My little Universal diesel over heated twice because I was not paying attention. After the second time I was more careful. However, after about 3 more hours of use it made a scraping noise and quit. It would restart but the noise was still there. I had it rebuilt. The engine shop had to replace a bent rod. Because it is a Kubota based engine I stripped it to the basic engine and sent it to a Kubota engine shop. Because the boat was new to me I had no idea of the engine history.
H and E is offline
Tags
diesel , engine , new engine , rebuild , repower
$6,600 to rebuild Atomic 4? replace/rebuild simmonct Atomic 4 73 03-13-2017 11:49 AM
Lightning rebuild jaydon Introduce Yourself 2 08-28-2012 07:49 PM
MacGregor 21 rebuild Jolley Roger MacGregor 21 03-08-2011 12:43 AM
hatch rebuild gtunison Gear & Maintenance 0 06-09-2010 10:01 AM
Question : Install New Engine vs Rebuild krozet Diesel 17 09-24-2009 06:30 PM
