yanmar vibration at low rpm - SailNet Community
post #1 of 3 Old 02-26-2014 Thread Starter
my mechanics have run out of idea's and i'm running out of money…
my '96 100hp yanmar diesel, 4JH2H-UTE vibrates….only in forward gear, only after reaching operating temp, and only between 700-800 rpm's. as perplexing as that is, listen to this.. once the shaking (which is not violent) begins, it will usually just stop within a minute or so even though nothing else has changed including the rpms. this condition has been around for 7-years and has never gotten worse or better. it is a nuisance to me, but apparently a big deal to a possible buyer.
here's what's been tried:
1. acqua drive /cv joint rebuilt
2. transmission pulled/inspected..meets specs
3. timing advanced/retarded..no change
4. fuel files/lines inspected..all clear
5. injectors checked
6. fuel filter leading to injector pump bypassed..no change
HELP
17spyglass17 is offline
post #2 of 3 Old 02-26-2014
night0wl's Avatar
Re: yanmar vibration at low rpm
Check your motor mounts...my boat had a nasty harmonic vibration between 2100 and 2300 RPM. Turned out that one of the mounts was bad.
S/V Jendai
Beneteau 343
night0wl is offline
post #3 of 3 Old 03-04-2014
In considering your dilemma, some things to note. The relationship between fuel delivery and load in forward and reverse are different and therefore the conditions are not matched at the same rpm, so the question is, what occurrences are there which could cause your problem which also correct themselves? Considering that the VE pump is the one component which is constantly transitioning itself between springs, hydraulic pressures and centrifugal forces, all of which are much more likely to show their flaw at lower rpms, my money is on your fuel pump. Pump characteristics change as they warm up and sometimes they change for the better, and sometimes not. My advice would be to have the pump removed and tested/reclalibrated specifying that you have this problem. Any fuel tech worth his 10 coffees will be able to sort this out for you.
Ahoyhoy is offline
Vibration starts at 2000 rpm Dave_E Diesel 8 10-27-2013 08:25 PM
Yanmar tach reads low rpm malyea Gear & Maintenance 11 06-05-2013 08:38 AM
Volvo MD5B vibration. RPM sweet spot? itsaboat Diesel 1 03-29-2013 11:56 AM
Yanmar stalls at low rpm markgoldfarb Diesel 2 06-26-2011 09:48 AM
Engine vibration between 1100-1200 RPM - Normal? zAr Gear & Maintenance 8 07-04-2009 12:49 AM
