seawater system - Page 2 - SailNet Community
 1Likes
post #11 of 12 Old 03-13-2014
Dirt Free
boatpoker's Avatar
Re: seawater system
Originally Posted by Samuelmonosov View Post
I agree with minnewaska there must be a loose fitting or opening somewhere in the line that is allowing for the vacuum in the line. Does it immediately empty, or does it take its time? Does that water run back to the engine or through the exhaust line? Speaking of which, you may want to check the exhaust line and make sure that it doesn't exit below the strainer. That would create the vacuum issue you are experiencing.
Sent from my iPad using Tapatalk
The OP reported the issue resolved in post#7
Be the man Sharon thinks I am - wg
I can do that
- wg
Be the master of your own disaster - wg
If you're not laughing, you're not doing it right. - wg
if you can live with the consequences, go for it. - wg
I yam what I yam an' thats all that I yam. - Popeye
boatpoker is offline
post #12 of 12 Old 03-13-2014
RichH's Avatar
Re: seawater system
Originally Posted by carlager View Post
The seawater strainer placed above sealevel and on the highest point on the seawater system on our Yanmar 3gm30f is empty when the engine is not running.
Is this normal ?
NO, its not normal as the contents of the strainer can drain-back and thus leave the strainer body full of air. If that slug of air reaches to the raw water pump, the pump may have difficulty 'priming itself' all the way to the pump ... especially as the pump normally wears/ages and the 'sides' of the pump vanes no longer 'seal' the impeller to the pump body vs. air. Once the pump and strainer are fully filled with water by the action of the pump, the water in the pump will make the proper seal to the sides; if the pump 'air leaks' past the impeller sides you may be running 'dry' pump for a long interval.
A strainer 'should' be below the waterline.
RichH is offline
slow drip, seawater pump ereiss Diesel 12 07-25-2012 09:23 PM
Engine seawater pump rebuild OceanNavigator Ocean Navigator 1 07-03-2012 03:04 PM
Battery Desalinates Seawater deow General Discussion (sailing related) 0 02-11-2012 02:27 PM
Using Seawater to cool Cabin DallasAB Gear & Maintenance 11 06-04-2007 11:55 PM
Freshwater to seawater ratio wanabe Cruising & Liveaboard Forum 30 04-24-2007 10:57 PM
