seawater system - SailNet Community
 1Likes
post #1 of 12 Old 03-10-2014 Thread Starter
seawater system
The seawater strainer placed above sealevel and on the highest point on the seawater system on our Yanmar 3gm30f is empty when the engine is not running.
Is this normal ?
carlager is offline
post #2 of 12 Old 03-10-2014
Group9's Avatar
Re: seawater system
I don't know. Mine is below sea level and stays full of water all of the time.
On the northern Gulf of Mexico.
"Best thing to do is get her out on the ocean. If anything's gonna happen, it's gonna happen out there." Captain Ron Rico
Group9 is offline
post #3 of 12 Old 03-10-2014
Re: seawater system
Is this normal ?
Doesn't sound 'normal' to me.. it also means your impeller must run dry on every startup for a moment.. Is there room to relocate it? Ours is also below waterline and always 'primed'.
jrd22 likes this.
Faster is online now
post #4 of 12 Old 03-10-2014 Thread Starter
seawater system
The impeller is on the other side of the strainer and does not run empty
carlager is offline
post #5 of 12 Old 03-10-2014
Re: seawater system
Are you saying the strainer is after the impeller? If the impeller is (properly) downstream of the strainer then it's pulling air for a bit until the system is once again flooded...
post #6 of 12 Old 03-10-2014
Dirt Free
boatpoker's Avatar
Re: seawater system
Faster is absolutely correct the impeller will run dry for a short period. Even if it is downhill from the strainer to the pump and that section of hose is full of water, the air in the empty strainer will get sucked through the impeller.
That impeller is going to have a very short life and failure will be sudden. When an impeller fails you have a few minutes at most to notice the overheat and shut her down or serious damage will occur.
Be the man Sharon thinks I am - wg
I can do that
- wg
Be the master of your own disaster - wg
If you're not laughing, you're not doing it right. - wg
if you can live with the consequences, go for it. - wg
I yam what I yam an' thats all that I yam. - Popeye
boatpoker is online now
post #7 of 12 Old 03-11-2014 Thread Starter
seawater system
You are right. The strainer should be full when the engine is not running. Greased the O-ring on the lid to the strainer. Now there is vacuum when the engine is not running and water In in strainer
carlager is offline
post #8 of 12 Old 03-11-2014
Dirt Free
boatpoker's Avatar
Re: seawater system
Glad you got it worked out. I'd recommend you pull that impeller for a close inspection and if possible reposition the strainer as low as you can get it, preferably below waterline (difficult in many sailboats).
I can do that
- wg
post #9 of 12 Old 03-12-2014
Re: seawater system
Could be an air leak at the strainer itself, or one of the hose connections. Clear seawater lines are great for detecting air leaks. You can see the bubble constantly flowing through.
Jeanneau 54DS
Minnewaska is offline
post #10 of 12 Old 03-13-2014
Samuelmonosov's Avatar
Re: seawater system
I agree with minnewaska there must be a loose fitting or opening somewhere in the line that is allowing for the vacuum in the line. Does it immediately empty, or does it take its time? Does that water run back to the engine or through the exhaust line? Speaking of which, you may want to check the exhaust line and make sure that it doesn't exit below the strainer. That would create the vacuum issue you are experiencing.
Sent from my iPad using Tapatalk
Samuelmonosov is offline
slow drip, seawater pump ereiss Diesel 12 07-25-2012 09:23 PM
Engine seawater pump rebuild OceanNavigator Ocean Navigator 1 07-03-2012 03:04 PM
Battery Desalinates Seawater deow General Discussion (sailing related) 0 02-11-2012 02:27 PM
Using Seawater to cool Cabin DallasAB Gear & Maintenance 11 06-04-2007 11:55 PM
Freshwater to seawater ratio wanabe Cruising & Liveaboard Forum 30 04-24-2007 10:57 PM
