1987 Westerbeke W10: PROBLEMS: HELP!!! - SailNet Community
post #1 of 4 Old 03-11-2014 Thread Starter
FIRST PROBLEM: When I attempt to start the motor, I can tell the starter will spin but it will not engage the flywheel. All the connections are tight and the batteries are fully charged.
SECOND PROBLEM: Below the engine I have recently started to notice large amounts of oil that have leaked out of the engine. There are no noticeable places I can actually see where the oil is coming from though. If anyone has had a similar problem please let me know what the diagnosis turned out to be.
Thanks for ya'lls help
ppage427 is offline
post #2 of 4 Old 03-11-2014
Learning the HARD way...
eherlihy's Avatar
Re: 1987 Westerbeke W10: PROBLEMS: HELP!!!
First Problem: Bendix Spring
Solution - remove starter, and take to a local auto-electric shop...Should cost < $100 to fix
eherlihy is offline
post #3 of 4 Old 03-11-2014
Second problem... clean it up best you can, lay down paper towels or oil matting, run the engine and see where it's dripping from. If it's a rear seal, oil hitting the flywheel may get flung around a bit, but if it's a leaky pan or other static leak you should be able to locate it - don't wait too long, just get the oil pressure up and the engine warm, dig out some earplugs, a flashlight and a mechanic's mirror and investigate.
Faster is offline
post #4 of 4 Old 03-12-2014 Thread Starter
Thanks for the help guys. I removed the starter and tested it on a battery, it spins but doesn't extend out. So I will bring it to a auto electric shop to have the bendix spring replaced, like you said. And it is a static oil leak, do you know where I could get a replacement oil pan?
ppage427 is offline
Westerbeke/Universal Diesel Problems stowe18 Gear & Maintenance 18 07-29-2013 08:51 PM
1987 26.5 cb32863 Hunter 0 10-10-2011 10:19 AM
Westerbeke 27 Starting problems 82Sabre34 Gear & Maintenance 2 05-25-2009 01:18 PM
1987 Newport 28 II drh1965 Newport 8 08-21-2007 02:58 PM
1987 Morgan 41 sailrman7 Boat Review and Purchase Forum 6 08-03-2007 11:22 AM
