Slow speed while motoring - SailNet Community
 2Likes
  • 2 Post By Close Quarters
post #1 of 8 Old 03-22-2014 Thread Starter
Close Quarters's Avatar
Hello!
1st time going out this season and I have very low speed in forward. Reverse is fine. In fact I go faster in reverse than forward. Over the winter, I would run the engine 30 minutes a week. 10 in neutral. 10 in forward. 10 in reverse. A month ago I started noticing I could only get 2200 RPM's in forward but I never go any higher than that but I still thought it strange. Certainly could achieve higher in rev and neutral.
My boat is a Pearson 323 with a rather new universal M-25XPB with 240 hours and the ZF 15 MIV transmission. My bilge is generally clear but today noticed it had a brownish orange discoloration with a slight foam on top. Not much actually more like a slight skim.
Kinda new to this so not real sure where to start. Hoping it's something simple but probably not knowing my luck.
Any suggestions, tips or hints would be greatly appreciated!
Cheers!
Bob
Close Quarters is offline
post #2 of 8 Old 03-22-2014
Lake Superior Sailor's Avatar
Re: Slow speed while motoring
Pretty hard to say much without more information......Dale
Reluctant Lady
Cal 28, 1967
Lake Superior
Where God got it done!
Lake Superior Sailor is offline
post #3 of 8 Old 03-22-2014
Sea Sprite 23 #110 (20)
mad_machine's Avatar
can you check the fluid in your transmission? Regular oil in water turns whitish.. but transmission fluid keeps a reddish to pinkish colour like this.
Art Haberland
In the end all that matters is how fully you loved, how gently you lived, and how gracefully you let go of things that did not belong to you -Buddha
mad_machine is offline
post #4 of 8 Old 03-23-2014
JimsCAL's Avatar
Are you running the engine in your slip or underway? if the former, I would expect lower RPMs. If the latter, what speed are you making in forward? Sounds like there was a recent change. Could just be an issue with the throttle cable.
As to the stuff in you bilge, could be a number of things. Certainly check the oil levels in the engine and transmission.
JimsCAL is offline
post #5 of 8 Old 03-24-2014
BarryL's Avatar
Hey,
Has the prop and bottom been cleaned recently? A typical result of a dirty prop and bottom is slow motoring performance.
Can you at least verify that prop is clean?
Good luck,
Barry
Barry Lenoble
Deep Blue C, 2002 C&C 110
Mt. Sinai, NY
BarryL is online now
post #6 of 8 Old 03-31-2014 Thread Starter
And the winner is. . .
Barnacles! ! !
Diver did the trick and everything is running well! Thanks for all the help!
Bob
Fstbttms and jimgo like this.
post #7 of 8 Old 04-01-2014
Check your prop pitch.
barefootnavigator is offline
post #8 of 8 Old 04-01-2014
Kynntana (Freedom 38)
gamayun's Avatar
It sounds like you've identified the problem, but I'd like to throw out one more thing that completely surprised me. I'd never been able to get full RPM out of my engine since I bought the boat last year. Thought it was an engine issue because the prop is original and the bottom is clean. The throttle cable broke a couple of weeks ago and when hooking it back up to the throttle handle, it had been installed wrong some time before, which meant that the idle position was OK, but it couldn't reach the upper limits. Obviously, a bad PO fix. The engine runs great, hits max RMP, and is burning off some white smoke these days....
gamayun is offline
Cape Dory 30 - How slow is "slow?" john2510 Boat Review and Purchase Forum 22 12-18-2012 03:21 PM
Slow, slow, slow and menu not responding cupper3 SailNet FAQ 35 05-05-2012 07:30 AM
C&C 99 motoring speed and a few others BarryL Boat Review and Purchase Forum 19 01-27-2011 05:18 PM
Gemini 105MC Slow speed under power TexasWill Boat Review and Purchase Forum 81 07-26-2010 11:26 PM
How slow is too slow before you use the motor? FarCry General Discussion (sailing related) 30 10-07-2008 02:09 PM
