Volvo MD7A transmission water leak. Bypass? - SailNet Community
post #1 of 4 Old 03-29-2014 Thread Starter
txmatt's Avatar
The housing of the transmission on my MD7A is cracked and leaking water. I was wondering if anyone has experience with running the transmission without water cooling? Terrible idea?
Matt
Cape Dory 28 "Dulcinea"
txmatt is offline
post #2 of 4 Old 04-09-2014
Re: Volvo MD7A transmission water leak. Bypass?
DON'T DO IT! unless you want to buy a new one....you might try what a friend did temporarily...he cleaned off all the paint and took it to bare metal, then made a "scab" patch with JB Weld...held for the season till he had a chance to have it welded professionally when he took it out and had it on the hard for the winter...Good Luck
simpsoned is offline
post #3 of 4 Old 04-09-2014
the pointy end is the bow
erps's Avatar
I'd probably try something like that myself (JB weld it) but only after confirming that the water leaks externally and not internally as well.
Ray
S.V. Nikko
1983 Fraser 41
La Conner, WA
erps is offline
post #4 of 4 Old 04-23-2014 Thread Starter
txmatt's Avatar
Thanks for the replies. I did put some of that underwater epoxy stuff over the crack and it slowed the leak down to a slow drip. Should get me through this season. I'll keep an eye on the oil for signs of water contamination. I see no oil in the water, so I figure that's a good sign.
simpsoned, Do you happen to know what your friend paid for that and what the outcome was (ie did the weld hold up over time). Cast iron is a pain to weld correctly. I had been thinking of trying to find a used one to swap in this winter.
Matt
txmatt is offline
Parting Out Volvo MD7A stuartlochner Diesel 20 11-25-2014 12:34 AM
Volvo/Penta MD7A paulinet. Diesel 8 09-12-2014 10:25 AM
Volvo MD7a Grand River Raider Diesel 13 02-11-2013 02:07 AM
Volvo MD7A-1977 Neicy Gear & Maintenance 6 11-09-2005 03:07 AM
Volvo MD7A BertV Gear & Maintenance 4 07-14-2003 07:59 AM
