About to buy, nagging engine issue - seeking advice - Page 6 - SailNet Community
 47Likes
post #51 of 58 Old 04-08-2014
ASA and PSIA Instructor
Re: About to buy, nagging engine issue - seeking advice
Originally Posted by Power For Sail View Post
$6K the yard's extract/installation work????? SERIOUSLY??? OMG, i need their salesman, LOL We would have charged no more than $2K....
That's sounds great, but I'd suggest it as somewhat un-professional to brashly toss out a number for a difficult job you likely don't understand (ever pull a W33 from a CS 36T...ever been on a CS 36T?). So some of the kids may be impressed but I am not.
sailingfool is offline
post #52 of 58 Old 04-08-2014
christian.hess's Avatar
here is an engine install on a 36t right here from sailnet
Repowering a CS 36T
am I missing something?
whats worth 6k to install?
a boom, chain pulleys and a standard new mounts, shaft alignment, prop change etc...
if you or anybody think 6k is REASONABLE for an install then well I congratulate you
you are in the 1 percent who thinks so
Merit 25 sold...Islander 36 still afloat? who knows...Im still in Columbus, and back...I think...jajajaja!!!!
christian.hess is offline
post #53 of 58 Old 04-08-2014
CBinRI's Avatar
My Perkins 4.108 definitely needed 12-15 seconds of glow if it was cold.
CBinRI is offline
post #54 of 58 Old 04-11-2014
Paid Sponsor
Power For Sail's Avatar
Not looking to impress anyone, Especially the fine members on this forum you are referring to as "KIDS" It is what it is. We guarantee it !!
PAID SPONSOR
Power For Sail is offline
post #55 of 58 Old 04-11-2014
snake charmer, cat herder
zeehag's Avatar
cb in ri.... we dont have em on ours here...is unnecesary ..mine is a quick start, when it ran..lol before it sed ka lunk...but it doesnt freeze here...ever.
and may is reinstall ka lunk month... want pix of how a lady installs an engine????
formosa 41, cruising tropics
zeehag is offline
post #56 of 58 Old 04-22-2014
It is my understanding that WD40 no longer has a flammable propellant and should not be used. In cold weather I hang a heat gun from the ladder and direct the heat towards the glow plugs and air intake, but not too close. Four or five minutes and 15 seconds on the glow plugs I have a quick start. 1981 Catalina 27.
christian.hess likes this.
BlueWind is offline
post #57 of 58 Old 09-25-2014 Thread Starter
Thought I'd post a follow up to this thread, as today I got some answers.
We ended up buying the boat, of course, and moved aboard a couple weeks ago. I put maybe 10 or so hrs on the engine over the summer, but it wasn't until we were aboard full time that I had the time to really look into this starting issue. The engine started blowing some black smoke, even when fully warm, in addition to requiring lots of cranking. On the advice of a local diesel mechanic, I pulled the injectors and found one to be wet w/fuel, all were pretty coked up. I took them in to be tested, and low and behold, they were ALL leaking, spurting, and generally in bad shape. The previous owner, who rebuilt the engine, claimed the injectors "have been rebuilt", though he didn't specify when. I suppose it's possible that they became fouled from a couple years of disuse...In any case, with rebuilt injectors installed today, the engine starts and runs perfectly, with zero smoke.
Thanks again for the discussion.
David
oldfurr likes this.
planetminder is offline
post #58 of 58 Old 09-27-2014
To anyone in the future, I would be very wary indeed about going near any motor that needs ether to start it.
The motor will get addicted to it very quickly, if it isn't already.
The ether will be detonating on the compression stroke as the piston rises and will pound the heck out of the piston crowns and the rings.
The owner must demonstrate to you that the engine starts reliably without narcotics.
Please don't touch it if it doesn't.
It will be nothing but trouble, and the trouble will worsen.
Rockter is offline
Need advice: Buy a boat for its engine? grinfax Gear & Maintenance 15 01-04-2012 04:47 PM
Re: Friend seeking to buy a 8 - 9 ft used dinghy NewsReader Mass Bay Sailors 0 07-10-2007 02:15 PM
