Yanmar super vibration - SailNet Community
 13Likes
post #1 of 48 Old 04-03-2014 Thread Starter
MY YANMAR 3YM30 IS SHAKING ITSELF TO BITS. It is 9 years old and 3000 hours and has run perfectly until 30 hours ago. The engine runs perfectly in neutral to full RPM. It also runs smoothly in reverse at all speeds. In forward gear, it runs ok until I shift into neutral and try to shift back into forward.
Then the engine starts to shake at 1000rpm and shakes horribly and starts a clacking / grinding noise at anything over 1200 rpm. It is truly frightening
On the advice of the Singapore dealer, I replaced the engine mounts and vibration damper. No improvement at all.
Finding an available mechanic here is very difficult, so any suggestions what to look into would be most appreciated.
meanderboy is offline
post #2 of 48 Old 04-03-2014
I don't discuss my member
Fstbttms's Avatar
Re: Yanmar super vibration
Better have a look at the running gear.
Fstbttms is offline
post #3 of 48 Old 04-03-2014
jsaronson's Avatar
Cutlass bearing?
christian.hess likes this.
jsaronson is offline
post #4 of 48 Old 04-03-2014
Crazy Woman Boat Driver
Melrna's Avatar
Location: Heading south down the US east coast to the Bahamas
Send a message via AIM to Melrna Send a message via Yahoo to Melrna
Bent shaft.
Melissa Renee
Moondance
Catalina 445, Hull #90
Melrna is offline
post #5 of 48 Old 04-03-2014
Remember you're a womble
PaulinVictoria's Avatar
If you go back into neutral and into forward again, does the problem go away? If not, if you back and forth a few times does it go away? Sounds like something isn't engaging in the gearbox (or transmission if you want to be all American about it). Could be something as simple as a cable adjustment needed, make sure when you are in gear that the shift lever on the gearbox is fully engaged.
Orange Crush
1974 C&C27 MkII
PaulinVictoria is offline
post #6 of 48 Old 04-04-2014
trantor12020's Avatar
What is a vibration damper? Where is it mounted?
I suppose you're based in Singapore? You could dismantle the gearbox and bring it to CLLS for them to service or contact Bobby Ee from Esgrit for some help/repair.
Ken
2002 Hunter 326, SV Millennium 2
1999 Macgregor 26X, SV Millennium
trantor12020 is offline
post #7 of 48 Old 04-04-2014
Have you actually checked your propeller? What you are describing is a classic symptom with a worn folding or feathering propeller or a bent blade on a fixed propeller.
Stanley,
Marine Diesel Engine Vendor
NCboatrx is offline
post #8 of 48 Old 04-04-2014 Thread Starter
just replaced cutlass 2 months ago. no play at all now.
post #9 of 48 Old 04-04-2014 Thread Starter
23 inch shaft is good on dial guage
post #10 of 48 Old 04-04-2014
I'm leaning towards a folding prop that's failing to fully open in forward at times.
On a former boat we got into the habit of spinning briefly in reverse before going forward - usually dealt with it.
Faster is online now
yanmar vibration at low rpm 17spyglass17 Diesel 2 03-04-2014 12:42 PM
Super Starters Audi Azzurra Sailing Team Lead The 52 Super Series NewsReader News Feeds 0 05-25-2012 09:20 AM
Vibration ! dbruce85 Boat Review and Purchase Forum 3 12-01-2008 11:14 PM
Vibration mtbmike Gear & Maintenance 7 05-28-2006 12:14 PM
Vibration mtbmike Gear & Maintenance 5 05-26-2006 11:55 AM
