shaft seal advice - SailNet Community
post #1 of 1 Old 04-04-2014 Thread Starter
shaft seal advice
We have a Radice RMTA drive shaft seal on our Yanmar 3gm30f in our Oceanis 36cc.
The boat is the water (saltwater) all year round with all seacocks open to prevent damages from ice.
Hope someone will share knowledge and experience on the following
1. Do I need to grease the shaft regularly ?
2. If yes can the grease inlet be used with the boat In the water ?
3. During spring the
will leak a couple of drops when the engine is idle with no throttle. Leak will stop with just a slight throttle in idle, in gear moving forward or backward and when water gets warmer later in the season even in idle with no throttle. Is this normal ?
carlager is offline
Shaft seal leak beanctr56 Gear & Maintenance 15 03-01-2011 10:00 AM
Pss Shaft Seal Magic1 Gear & Maintenance 16 10-07-2010 01:03 AM
PSS shaft seal Windborn Gear & Maintenance 26 02-01-2009 10:10 PM
Lasdrop Shaft Seal...Help? T37Chef Gear & Maintenance 4 03-27-2008 10:01 PM
Shaft seal Edo Kazumichi Gear & Maintenance 9 11-23-2006 11:03 AM
