yanmar 2QM20 to 3GM30F repower - SailNet Community
post #1 of 5 Old 04-06-2014 Thread Starter
Hello - I have a '79 C&C 34 with a trusty 2QM20 and have the opportunity to "upgrade" to a well maintained and conditioned 3GM30F. Primary interest is the 30 is freshwater cooled, smaller, lighter and a bit more power. I think I have a handle on the bed spec dimensions, the 30 has a bit smaller footprint. Wondering if anyone has done this repower with these models before and can offer and advise or other considerations. The 30 comes with a 2.61 transmission, so I will need a new prop. I think the exhaust set up is similar.. etc, etc;
Many thanks!
ps. still snowbanks here is Portsmouth NH...
wsconner is offline
post #2 of 5 Old 04-06-2014
Re: yanmar 2QM20 to 3GM30F repower
Besides the footprint itself, be sure to check side clearances up high - alternators/belt pulleys may be in different spots?.. the shaft coupling position vs engine mounts may be slightly different too, will the original shaft fit?
Yuck....
Faster is offline
post #3 of 5 Old 04-06-2014
Dog Ship's Avatar
Our C&C 32 was upgraded from it's original A-4 to a 3GM30F. The shaft was replaced from it's original 7/8" to a 1" diameter shaft and a fixed 3 blade prop of an unknown size. The motor itself is a tight fit and is difficult to work on.
Ours is fresh water cooled.
Other than the engine mounts, the fuel tank and the shaft, there were no further modifications.
However, the exhaust outlet was not changed and it is smaller by 1/2". It does not seem to cause any problems. The engine has almost 600 hours on it and has run flawlessly for 6 years now.
It's a bit over powered but it is nice to know that I can travel through some of our Gulf Island passes with the tide running and make it. It will cruise all day long at 7 knots and 2700 rpm.
We have three rules;
No screaming.
No bleeding on the sails.
No slobbering on the charts.
Dog Ship is offline
post #4 of 5 Old 10-23-2014
Interesting. I have a C&C 32 I am considering re-powering, I find the Yanmar that's in the boat just doesn't have enough power for 'cruising'. You are the second owner I have come across with a 30HP. I was thinking 25 but maybe I am setting my sights too low.
markstoport is offline
post #5 of 5 Old 10-25-2014
JimsCAL's Avatar
The prop is probably more important than a few more horsepower. Make sure you have a correctly sized prop before considering an engine change. The important thing is the thrust developed by the prop, not the power produced by the engine. Delivering more power to an undersized prop will not help anything.
JimsCAL is offline
Oil for Yanmar 3gm30f? carlager Diesel 4 11-27-2013 07:32 AM
Winterizing a Yanmar 2QM20 rikhall Diesel 3 11-24-2013 12:03 AM
repower 2QM20 with 3YM30 wsconner Diesel 2 09-19-2010 10:21 AM
Yanmar 3GM30F aa3jy Diesel 7 11-23-2009 09:45 AM
Yanmar 3GM30F Bill Mc Gear & Maintenance 30 11-28-2007 08:51 PM
