yanmar ysm8 tick slap - video - SailNet Community
 1Likes
post #1 of 15 Old 04-06-2014 Thread Starter
Hi Guys
Im interested in purchasing an old small sailboat with an equally small and old yanmar.
The engine powers the boat long just fine, seems to run well and smokes little, if at all.
However it has a very pronounced slap like noise.
Let me know what you think
https://www.youtube.com/watch?v=jBhG...ature=youtu.be
cowlum is offline
post #2 of 15 Old 04-06-2014
Lake Superior Sailor's Avatar
Re: yanmar ysm8 tick slap - video
Sounds just like mine!....Dale
Reluctant Lady
Cal 28, 1967
Lake Superior
Where God got it done!
Lake Superior Sailor is offline
post #3 of 15 Old 04-06-2014
bljones's Avatar
seemed to start okay.
It's 5 o'clock somewhere:
bljones is offline
post #4 of 15 Old 04-06-2014
Sounds like the African Queen on the run, It's a single Banger. Pushes to hull speed and burns 1 liter per hour. mine is also a V drive !....Dale
Reluctant Lady
Cal 28, 1967
Lake Superior
post #5 of 15 Old 04-06-2014
bljones's Avatar
A YSM8 through a v-drive? Egad, it probably has 3 hp at the prop.
Cowlum, was a that a cold start? First start of the day?
bljones is offline
post #6 of 15 Old 04-06-2014
Maybe , YSM 8 is only 7hp .....Dale
Reluctant Lady
Cal 28, 1967
Lake Superior
post #7 of 15 Old 04-07-2014 Thread Starter
Yes, it should have been the first start of the day. I asked the owner to specifically not start the engine before I arrived, he seemed trust worthy.. The block was cold to the touch and it started much easier once warm.
It may be low power but it had no issues with a 1.8-ton boat. Besides,in my price range I cant be too choosy..
cowlum is offline
post #8 of 15 Old 04-07-2014 Thread Starter
I just looked up what a vdrive is.. This boat doesnt have a vdrive, its a forward mounted engine. What you are lookiing at is an engine mounted under the v-birth.
Thanks
cowlum is offline
post #9 of 15 Old 04-07-2014
Yes : but mine is and it does the job well . My boat is 28ft. and 6000lbs empty so it should do well for you!....Dale
Reluctant Lady
Cal 28, 1967
Lake Superior
post #10 of 15 Old 04-07-2014
No Experience with that engine, but some with others. I have noticed that when cold some sound similar, but with a single it is more noticeable. After getting to full operating temp, the metallic type noise seemed to mellow out. There is a whole lot of commotion going on in there when it fires. If it starts easily, runs alright, pushes the boat, doesn't heat up or smoke excessively, use excessive amounts of oil, and the coolant is not milky, it is probably/possibly good for a while. A good long hard run should show any severe problems. An oil analysis may show severe wearing or excess fuel problems.
Paul T
dabnis is offline
Yanmar YSM8 Oil Leak sblake1961 Diesel 2 08-01-2014 06:47 PM
Find used Yanmar YSM8? Harborless Diesel 3 12-25-2013 05:19 PM
yanmar ysm8 must it have easystart? culamnelson Gear & Maintenance 5 09-08-2011 09:21 AM
yanmar YSM8 speed suggestions birdlives Diesel 7 12-12-2010 06:41 AM
Hard Warm Starting Yanmar ysm8 mhfowle Gear & Maintenance 7 12-20-2006 01:45 PM
