oh oh water pump - SailNet Community
 9Likes
post #1 of 29 Old 04-26-2014 Thread Starter
One of None
deniseO30's Avatar
oh oh water pump
Engine coolant leaked over the winter.. from the engine water circulation pump (not raw water) I'm hoping if I top it off when the engine starts running again the leak will not be bad. if not.. guess it's time to order a new pump from tractor smart! Universal 5416
My last project!
deniseO30 is offline
post #2 of 29 Old 04-26-2014
fryewe's Avatar
Re: oh oh water pump
I have never known a leak like this to get better with age.
The web makes everywhere the same place. - Fred Reed, from "Fred on Everything"
fryewe is offline
post #3 of 29 Old 04-26-2014
Maybe, f you are lucky, the seal hardened up a bit over the winter, and as anti-freeze is really slippery stuff, a bit of leakage may not be too bad. Suggest you run it a bit before ripping the pump out. It may soften the seal up a bit & solve the leak, maybe? Nothing to lose unless it is gushing out.
Paul T
deniseO30 likes this.
dabnis is offline
post #4 of 29 Old 04-26-2014 Thread Starter
One of None
deniseO30's Avatar
It's leaked a bit before. Maybe when it starts spinning again but it's not going to fix itself for sure!
It didn't loose allot of water, but enough it had me thinking the block cracked!
My last project!
post #5 of 29 Old 04-26-2014
you already did it when you thought block cracked but, check engine oil for water
(antifreze).
Zen is a matter of recognizing reality.
desert rat is offline
post #6 of 29 Old 04-26-2014 Thread Starter
One of None
deniseO30's Avatar
I will check but with 100% antifreeze I would think not.
Seems like the right part number 15321-73032
My last project!
post #7 of 29 Old 04-27-2014
100% anti-freeze? Never ran 100%, but have read it doesn't cool as well as 50%, which I think is good for about minus 30 degrees F? May not be a big deal, but if your engine specs call for 50% your warrantee may be compromised? Just a thought.
Paul T
dabnis is offline
post #8 of 29 Old 04-27-2014 Thread Starter
One of None
deniseO30's Avatar
On a 30 + year old engine Paul?
fryewe likes this.
My last project!
The Following User Says Thank You to deniseO30 For This Useful Post:
hangupndrive (06-27-2014)
post #9 of 29 Old 04-27-2014 Thread Starter
One of None
deniseO30's Avatar
checked the oil no water showing on the stick. just black as always. will "top it off" see what and how much drips .. still working on the electrical systems. Sigh.
5 30pm Just left the boat the leak was the weep hole of the pump. so far it's not leaking now.. will check again tomorrow.
My last project!
post #10 of 29 Old 04-27-2014
Superior Sailor
Squidd's Avatar
Leaking thru weep hole indicates a worn shaft bushing...time to replace the pump.
"Might as well take 'er out...If anything is gonna happen...It's gonna happen out there..."
"Captin Ron"
Squidd is offline
Water Pump/Hot Water Heater/Breaker Trips DINKS14 Gear & Maintenance 5 03-10-2014 11:31 PM
Water Pump nickmerc Atomic 4 6 01-24-2011 12:44 PM
1 gm 10 water pump odayrockaway Diesel 0 11-22-2009 06:09 PM
Need water pump? saltypat Gear & Maintenance 1 05-29-2009 03:08 PM
Water Pump? brianontheroad Gear & Maintenance 2 02-10-2009 09:34 PM
