Yanmar 2QM15 Tranny Noise - SailNet Community
post #1 of 4 Old 05-05-2014 Thread Starter
Hi
I'm a new member to SailNet and a new owner of a 1979 Spirit 28. I'm in the cleaning and fluid changing stage now and have not had her sailing yet. When I start the engine and put the shifter in forward I get a whining noise from the tranny , but no noise in reverse. It's not that loud but it's is a whine. Is this normal? I am only shifting forward and reverse in the slip so I can't leave it in gear for a long time. It makes this noise before and after I changed the AFT. I read that the transmission must be fully engaged or you can damage it so I will check the shifter cable to make sure it is. Do these transmissions have a different sound in forward then reverse? Thanks in advance. Brian
Brian Buzz is offline
post #2 of 4 Old 05-05-2014
christian.hess's Avatar
Re: Yanmar 2QM15 Tranny Noise
nope adjust cable
for example atomic 4 are famous for always having that whinning in reverse as the clutch never fully engages and isnt designed to
for your engine though in forward it shouldbe a solid engagement
have a helper move the throttle and shifter while you are donw by the engine
the best way to do this is to actually disengage the cable so you can manually see where engagement has ocurred then adjust cable and mount to desired cable "throw" or range if you will
Merit 25 sold...Islander 36 still afloat? who knows...Im still in Columbus, and back...I think...jajajaja!!!!
christian.hess is offline
post #3 of 4 Old 05-05-2014
fryewe's Avatar
If you have the Kanzaki-Carl Hurth KBW-10 transmission and don't have the tech manual...PM me and I'll send you the Tech Manual pages that describe linkage/shifter adjustment.
The web makes everywhere the same place. - Fred Reed, from "Fred on Everything"
fryewe is offline
post #4 of 4 Old 05-06-2014 Thread Starter
Thanks for the info. I just got home from the boat. More cleaning and maintenance. I had a friend in the cockpit shift the lever slowly as I was down by the tranny. The tranny shifted all the way forward, even past the part when it click into gear. It did the same in reverse. I then started the motor and had my friend shift the tranny into forward and reverse, the shaft turned in both F and R but the tranny had a whine in forward only. I can only do this for a few seconds because I an tied to the dock. The ATF looked clean when I pumped it out? I will have my insurance tomorrow in effect so I can go for a test cruise to see if anything changes. I also have the Manuals and will look at them tonight. Thanks for the offer to send them to me. Any help is appreciated.
Brian
Yanmar Tranny Larry D News Feeds 5 07-08-2012 03:04 PM
Installing tranny on Yanmar 2ym15 ... should I? lawsonmitchell Diesel 1 02-21-2012 03:13 PM
Yanmar tranny clunks on engagement jarod Diesel 5 03-28-2010 09:19 PM
Yanmar 2gm Tranny separation help!! jackmace Gear & Maintenance 3 03-09-2008 08:50 AM
Yanmar 2gm Tranny separation help!! jackmace Gear & Maintenance 0 02-19-2008 12:19 AM
