Need Yanmar 3JH3E fuel consumption datasheet - SailNet Community
post #1 of 4 Old 05-05-2014 Thread Starter
Does anyone have an old technical datasheet for a Yanmar 3JH3E engine that has the graph showing fuel consumption at different RPM? I figured consumption for my engine at 2,500 RPM by filling the tank, motoring at 2,500 RPM for a few days, and refilling the tank to see how much it took, but I can't do that at every possible RPM.
Yanmar's web site only has datasheets for current model engines, and the only place I can seem to find these datasheets online is on BoatDiesel.com, and they want me to pay $25 to read a datasheet that Yanmar used to hand out by the thousands for free at boat shows. I can't bring myself to pay it.
Thanks!
jim2ksb is offline
post #2 of 4 Old 05-09-2014
Stu Jackson's Avatar
Re: Need Yanmar 3JH3E fuel consumption datasheet
It really doesn't matter.
Really.
Over the course of operations, you'll run your engine at vastly different rpms.
ALL you NEED to know is the average fuel consumption, and what you did by running around and refilling is exactly how to do it.
Fuel Log
Stu Jackson, Catalina 34, 1986, M25 engine, Rocna 10 (22#), Maple Bay, BC, Canada
Stu Jackson is offline
post #3 of 4 Old 05-11-2014
DrivinSteve
Really.
Fuel Log
With all due respect to Mr. Jackson,
Average consumption is a nice to know; but what you really NEED to know is, in a pinch, what "performance" can I get per hour at the low end (max endurance/range) or, if I need to run fast for weather/tide/daylight/injury, do I have the fuel to do that. For instance, how fast can I make a Closest Point of Approach" to get/give help. I may need to adjust my plan if the fuel available prevents me from fighting a foul tide to make my destination. At what throttle setting do I get my "hull speed" and in what sea state does adding throttle just waste fuel for no incremental gain.
If you don't buy the safety aspect, think about a plan to buy fuel in the least expensive places by giving up half a knot (500RPM) to get there with some reserve.
DrivinSteve is offline
post #4 of 4 Old 11-27-2014 Thread Starter
In case anyone else ever has this question, I finally located the Yanmar 3JH3E datasheet at www.simplicity-marine.com/pdf/yanmar/jh.pdf.
jim2ksb is offline
Yanmar 3JH3E RPM gauge intermittent MooGroc Diesel 0 09-15-2013 07:21 AM
Fuel Consumption vega1860 General Discussion (sailing related) 17 12-25-2011 11:46 AM
Need Valve lash spec Yanmar 3JH3E doubleeboy Diesel 2 03-28-2010 10:11 PM
Yanmar 2QM15 fuel consumption? 30Irwin Diesel 9 09-04-2009 11:17 PM
Yanmar 1GM Diesel fuel consumption H216Sailor Gear & Maintenance 15 04-03-2008 08:17 PM
