Cleaning my Yanmar injectors? - Page 4 - SailNet Community
 12Likes
post #31 of 44 Old 05-19-2014
Senior Smart Aleck
jameswilson29's Avatar
Re: Cleaning my Yanmar injectors?
Originally Posted by Dave Montgomery View Post
Mr. Wilson, The only thing clearly evident is that you have nothing to offer. As usual, big hat, no cattle. Another assessment is simply that you are a jerk. I'll settle on the latter.
Thanks to the rest if you for your insights.
Mebbe you should consider a new hobby, like crocheting or interpretive dance?
I hear some people really enjoy scapbooking!
jameswilson29 is offline
post #32 of 44 Old 05-20-2014
Freedom 39
FarCry's Avatar
I've been on SN for 7 years and you are the first person that's motivated me to research this function. Congratulations!!!-------
Can I block posts, emails and messages from specific users?
If there are particular members that bother you and you do not want to see their posts or receive Private Messages and Emails from them, then you can add these members to your 'Ignore List'. There are several ways to do this:
Through your User Control Panel: User CP, Settings & Options, Edit Ignore List. Then, type their name into the empty text box and click 'Okay'.
jameswilson29 likes this.
FarCry is offline
The Following User Says Thank You to FarCry For This Useful Post:
jameswilson29 (05-20-2014)
post #33 of 44 Old 05-20-2014
Senior Smart Aleck
But that means you will miss out on this:
post #34 of 44 Old 05-20-2014
Ah!!, the ignore list, I am proud to be on several/many of those, great fun. I am not even close to being an expert on anything but do have some experience on VW & Detroit diesels.
Suggest:
1. A good, detailed shop manual, read thoroughly before further wrenching
2. Check lift pump pressure at cranking speeds, assuming all filters are flowing properly.
3. Check injector pump timing
4. Check valve clearances
5. Check for any air leaks by pressurizing the fuel system from the tank outlet downstream
6. Use the new injectors, can't remember if you have already done this?
7. Make sure your battery is at full capacity & that all connections are fresh & clean
8. An oil analysis and or a compression test may provide further info.
Paul T
dabnis is offline
post #35 of 44 Old 05-20-2014 Thread Starter
Just please go away. You clearly have nothing constructive to say or offer. Many folks here have been interested in this topic and those folks and myself have benefitted from trying to find reasonable solutions. Why you feel a need to judge me for my efforts or categorize me as inept is so infantile. You must have better things to do with your time, or not. I would like to continue my discussion on the open forum with others. Please do not add any more comments.
Dave Montgomery is offline
The Following User Says Thank You to Dave Montgomery For This Useful Post:
post #36 of 44 Old 05-20-2014
Senior Smart Aleck
Proud to be on an ignore list??? Huh, this is BEYOND BELIEF!!!
That does it, that is the final straw, Mr. Smart Guy, you are now officially on my ignore list...
...and I am very, very important and special!
Plus, stop responding to all my posts! What do you think this is, a listserv or sumptin?
post #37 of 44 Old 05-20-2014
Dave, as you posted this shortly after my last post, I assume you are shooting at me? If so, my apologies.
Paul T
dabnis is offline
post #38 of 44 Old 05-20-2014
[quote]
A little humor?
You will have to stand in line
So noted.
Paul T
dabnis is offline
post #39 of 44 Old 06-12-2014
GreatKetch33
Deric's Avatar
Update:
I learned this week that Macboring, NJ has closed down the fuel injector service shop. I wanted to have them service the injectors and they said that they don't work on them, even if one was a student in their workshop class.
Don't intend to hijack thread, but finding a good reputable place for injector work takes research.
Deric is offline
post #40 of 44 Old 06-13-2014
trantor12020's Avatar
Can I assume a brand new set of Injectors would have been factory calibrated and ready for immediate use?
Ken
2002 Hunter 326, SV Millennium 2
1999 Macgregor 26X, SV Millennium
trantor12020 is offline
injectors??? nolasailor Diesel 12 01-03-2013 01:19 PM
Yanmar YSE12 injector cleaning thedigitalforge Diesel 16 03-11-2011 12:48 PM
no fuel at injectors chuckg5 Diesel 11 06-10-2010 08:23 PM
Injectors for m18 Flfishindude O'Day 0 11-09-2009 12:43 PM
Yanmar 1GM10 cooling system, needs a good cleaning. SVDistantStar Gear & Maintenance 4 01-13-2008 03:14 PM
