Two questions about new fuel tank install - Page 2 - SailNet Community
post #11 of 18 Old 06-01-2014
CaptainForce's Avatar
Re: Two questions about new fuel tank install
Originally Posted by Bernie Hoban View Post
On the subject if fuel tanks, we just discovered our catalina 309 (2008 year) tank is corroided on the bottom. We are shocked that a six year old well kept boat would have this problem and we are baffled how moisture may have gotten into the space.
Please clarify for us if this was an aluminum tank and the nature of the bottom surface. Was it flush with wood, fiberglass, on runners or otherwise ventilated.
Take Care and Joy, Aythya Crew
CaptainForce is offline
post #12 of 18 Old 06-01-2014
Hi the tank is aluminum and it appears to be sitting right on the hull
Bernie Hoban is offline
post #13 of 18 Old 06-02-2014
Freedom 39
FarCry's Avatar
Within a two week period both of my aluminum fuel tanks started leaking. The tanks both had corrosion in the bottom in an area I will call a "sump" for lack of better terms. The rest of the interior and exterior of the tanks is pristine. The tanks are about 30 years old. The tanks hang from tabs welded along the top and corroded from the inside out.
FarCry is online now
post #14 of 18 Old 06-02-2014
I understnd the risk of the corrosion of aluminum tanks next to a hull that gathers moisture from condensation or at wet bottom surfaces without good ventilation. I would be concerned about corrosion from the bottom inside the tank and wonder about the cause; however, I'm not sure how one determines that the corrosion originates from inside the tank. I'd like to hear the method that would be used to determine wether the corrosion begins on the inside or outside and also, what thoughts knowledgeble people might have about additives in diesel fuel that might corrode aluminum.
post #15 of 18 Old 06-02-2014
Freedom 39
FarCry's Avatar
In my case the aluminum sump was cut off and the inspection port on the top removed. The inside of the tank where the leak was looked like a termite/acid ate away an area approximately 3/8" in diameter from the inside. The outside of the tank looked like a tiny crack. The exterior surface was flush. It was pretty obvious even if my description isn't clear.
post #16 of 18 Old 06-03-2014
Originally Posted by FarCry View Post
............. The inside of the tank where the leak was looked like a termite/acid ate away an area approximately 3/8" in diameter from the inside. The outside of the tank looked like a tiny crack. The exterior surface was flush. It was pretty obvious even if my description isn't clear.
No, this is clear and well said. I think the thought that the inside of the tank having a larger surface area of corrosion than the outside would be compelling evidence.
post #17 of 18 Old 06-03-2014
Freedom 39
FarCry's Avatar
After cleaning up the tank, I will call it tank #2, and seeing that many areas had very deep corrosion and pitting on the interior, I went ahead and ordered a replacement from the original manufacturer. Since tank #2 seemed to have more water and crud in it than fuel and still managed to last 30yrs, I figured a new one will last at least that long with some minor attention.
post #18 of 18 Old 06-22-2014
There's a good article somewhere on the net on how to install an aluminum tank. Basically, DON'T let it sit on a surface - use non-metallic, non-absorbing (read plastic) strips to allow air circulation. And don't paint it. Basically avoid anything that would allow moisture to attack the tank.
As for the anti-siphon valve, I can't see why you'd need it and as you say, it's one more thing to go wrong. What you DON'T want is an airleak anywhere in the fuel intake.
druid
druid99 is offline
Fuel tank install sailordave Diesel 1 09-11-2012 08:13 PM
Fuel Tank Questions nereussailor Gear & Maintenance 2 05-22-2009 11:43 AM
Irwin 34 Fuel tank questions rikhall Irwin 8 03-03-2009 01:21 AM
New Fuel Tank - questions sailor25b Gear & Maintenance 16 02-17-2009 06:57 AM
Best Way To Install Fuel Tank Martinini Gear & Maintenance 1 06-27-2008 01:56 PM
