Heat Exchanger Gasket? - SailNet Community
 1Likes
  • 1 Post By hellosailor
post #1 of 8 Old 05-22-2014 Thread Starter
I have a Universal M50 diesel and I am cleaning up the heat exchanger and need new gaskets for the two end plates.
Can I replace the old gaskets with gasket material I buy from the auto store? I think I saw some suitable for the coolant system. Would these be OK?
Thanks - jballou
jballou is offline
post #2 of 8 Old 05-22-2014
Re: Heat Exchanger Gasket?
jb, the art of cutting gasket material is a lost art. But the process still works as well as it always did.
Gasket material (the correct material & thickness for the purpose) or even a product like Permatex "Form A Gasket" should be perfectly good, as long as it is the right thickness, and suitable for use in coolant. Probably a lot cheaper and faster than ordering gen-you-whine marine gaskets, as long as you don't mind cutting it to match.
christian.hess likes this.
hellosailor is offline
The Following User Says Thank You to hellosailor For This Useful Post:
jballou (05-22-2014)
post #3 of 8 Old 05-22-2014 Thread Starter
Great - thanks very much. Will proceed with making a gasket!
jballou is offline
post #4 of 8 Old 05-23-2014 Thread Starter
Hmm - the gasket material I am finding is not as thick as the gaskets on the heat exchanger that need replacing. The original gaskets were about 1mm think and quite rubbery.
Any suggestions on material that I can use? An old auto tire inner tube?
thanks -
jballou is offline
post #5 of 8 Old 05-23-2014
christian.hess's Avatar
you can coat homemade gaskets with that rubber compund I forget the name...it will add to the thickness if not ask for other gasket materials...there many to chose from, cork, rubber, paper, etc...
making gaskets is great, I made them all the time on my motorcycle as it saved me from having to wait for shipping from the states...
pay attention to thickness like mentioned and youll be fine...and dont go overboard with the usea of sealants...a thin film is all thats needed...
cheers
Merit 25 sold...Islander 36 still afloat? who knows...Im still in Columbus, and back...I think...jajajaja!!!!
christian.hess is offline
The Following User Says Thank You to christian.hess For This Useful Post:
jballou (05-23-2014)
post #6 of 8 Old 05-23-2014
DANCO 6 in. x 6 in. x 1/6" Rubber Packing Sheets (2-Pack) for less then $5.00 at Home Depot or any plumbing supply store.
Hudsonian is offline
The Following User Says Thank You to Hudsonian For This Useful Post:
post #7 of 8 Old 05-23-2014 Thread Starter
Thanks! I love this forum.
jballou is offline
post #8 of 8 Old 05-23-2014
And if all else fails, usually NAPA stores have a better selection of "real" auto supplies like that. Inner tube rubber used to be good stuff, but I have no idea what it actually is these days, and it is often not flat.
Grainger and McMaster, both online and with nationwide stores, carry these type of materials in a very wide range for industrial customers.
Heat exchanger Flfishindude O'Day 5 08-17-2013 09:07 AM
Hole in heat exchanger klubko Diesel 24 02-17-2011 08:19 PM
Universal M-18 Heat exchanger jlenox Gear & Maintenance 9 05-02-2009 04:55 PM
Heat Exchanger help DBboat Gear & Maintenance 14 05-20-2008 04:57 PM
heat exchanger Jovietal Gear & Maintenance 4 04-03-2007 03:59 PM
