Volvo md7a overheating, temperature fluctuating - Page 2 - SailNet Community
 5Likes
post #11 of 38 Old 05-23-2014
christian.hess's Avatar
Re: Volvo md7a overheating, temperature fluctuating
yeah change oil and see if you get a smell in the oil quickly, if you do leak somehwere and its thining out your oil
oh I found this:
http://www.bluemoment.com/manuals/Vo...A_Workshop.pdf
and regarding the oil I guess it is just thinner than normal...just make sure it doesnt smell real bad of diesel...
you should be using 20w in temps over 50...straight grade...so get a good quality one...
30 might be a good choice since the engine is old...might help a bit...
cheers
Merit 25 sold...Islander 36 still afloat? who knows...Im still in Columbus, and back...I think...jajajaja!!!!
christian.hess is offline
post #12 of 38 Old 05-23-2014
Originally Posted by txmatt View Post
I did not do any sort of acid bath, just poked out the passages with a coat hanger. I'm thinking some sort of acid soak might be my next step. I just noticed a thread from about a month ago from a fellow with a MD6a with a similar issue that was resolved using an icemaker descaling solution.
The thermostat is a sierra aftermarket. No idea what the previous one was, it looked the same though. Testing it would make sense but for that to be worthwhile I'll have to get a thermomitor
Mixing elbow is clear, I checked that when the manifold was off.
Oil is supposed to be 20 or 30 weight, I haven't changed it yet.
Thanks for the replies.
how long, hours since last oil change?
do that first that way you can see if yoy are getting fuel into the oil
cheers
post #13 of 38 Old 05-23-2014 Thread Starter
txmatt's Avatar
I don't think it's all that thin. It took me quite awhile to get a halfway decent picture of it, so I think that's contributing to that apperance in the photo. I didn't notice a fuel smell in the oil but I can check again tonight. Straight 20 weight is considered acceptable so for all I know that's what the PO had in there
How would a leak in the fuel pump cause overheating? just by degrading the oil? The oil is really old so fuel leak or no it's probably not doing it's job very well, but I wouldn't expect that to cause this sort of overheating. I was going to wait till I had the cooling issues sorted out before changing it, but now that I have a tstat back in I guess I should go ahead and do it.
Matt
Cape Dory 28 "Dulcinea"
txmatt is offline
post #14 of 38 Old 05-23-2014 Thread Starter
txmatt's Avatar
cheers
No idea (new to me boat). The fuel filter I took off the engine appears to have been there since 2005... Maybe the oil was last changed then too? In any case, it definitely needs to be done. Didn't think the temp would be very sensitive to oil quality though?
Matt
txmatt is offline
post #15 of 38 Old 05-23-2014
oh yeah it can...one of the first things I ever do on any engine new to me, old or ne is to change fluids asap no matter what the op says...
one of those things...really old oil lubricates and cools less also has sludge....
so it might or might NOT be a factor but an oil change would be the first things I would do, especially since the boat and engine is new to you.
straight grade oils naturally will be thicker feeling than multigrade and are in essence better since there are no viscous changing detergents and the like.
so get a good straightgrade 20 oil and see if it makes any diffrerence...or of it feels different too
thats the first thing id do...that way you start fresh and can see if the oil turns dark real soon, or of it smells soon of fuel etc...
uncle stinky bob likes this.
post #16 of 38 Old 05-23-2014
if you are using an engine that has almost 10 year old oil
STOP
post #17 of 38 Old 05-23-2014 Thread Starter
txmatt's Avatar
STOP
lol, yes. I did the fuel filters last weekend and was pretty shocked at the date written on the filter (it was either 05 or maybe 09 if the PO was european, though I don't think he was.) Was also shocked that the engine ran at all given their state. I don't think the oil is really that old, but the fuel filter has me pretty suspicious of the PO's maintenance habits. Didn't want to change it till I had a tstat in (couldn't get it up to temp to drain it without one), but will do that asap now that I do have one
Matt
txmatt is offline
post #18 of 38 Old 05-23-2014
yeah man one of those things...start off with know quality and quantity and go from there
ps a cheap thermometer for cooking works great for testing thermostats, and they are cheap...that way you can test it out too
good luck
post #19 of 38 Old 05-23-2014
The thermostat that is in now might be for a Fresh Water cooled engine so it is opening up at 150 degrees or so when a Raw Water thermostat might open at 125 degrees. If you have the box it came in it should say on the box at what degree it will open. The manual should tell you what temp it should run at.
Oh and change the oil and maybe the filter twice! Good Luck.
Froggy is offline
post #20 of 38 Old 05-24-2014
yup
you have to determine at what temp that thermo opens, only way to do that is to boil it...and see if it does it so correctly and at what temp and repeateadly, you might want to look at getting an oem thermo from volvo penta too...
many a times have I had 2 thermostats for my vehicles one for cold weather and one for hot weather...
anywhoo
good luck
ps. did a bunch of research on volvos last night(im sans an inboard on my boat as the palmer gas inboard died) and there are some sweet running md7a, md11c, md2b 2020,2030 etc out there that gave me some inboard envy for sure!
so take care of yours! jajaja
Parting Out Volvo MD7A stuartlochner Diesel 20 11-25-2014 12:34 AM
Volvo MD7a Grand River Raider Diesel 13 02-11-2013 02:07 AM
Volvo MD7A Overheating Solved? harbin2 Gear & Maintenance 6 05-09-2011 07:40 PM
white smoke and overheating on MD7A dobravila Diesel 14 07-06-2010 06:24 PM
Volvo MD7A BertV Gear & Maintenance 4 07-14-2003 07:59 AM
