Yanmar 3GM30F - SailNet Community
 1Likes
post #1 of 23 Old 06-05-2014 Thread Starter
Yanmar 3GM30F
Engine runs good for about an hour...3,000 RPM's...then starts to "hunt" and RPM's drop to 1,000..have replaced everything...lines, filters, injectors etc but problem persists.
blavin is offline
post #2 of 23 Old 06-05-2014
Warm Weather Sailor
Vasco's Avatar
Re: Yanmar 3GM30F
How's your fuel? 30,000 is a bit high for a 3GM30F maybe 3000.
Rick I
Toronto in summer, Bahamas in winter.
Vasco is offline
The Following User Says Thank You to Vasco For This Useful Post:
blavin (06-05-2014)
post #3 of 23 Old 06-05-2014
dockbum
dockbumdan's Avatar
Re: Yanmar 3GM30F
sounds like you sucking air, re-bleed fluel lines check for air leajks around filters, etc
DockbumDan
SV/Trinity
Sailing Associates
Slip W=11
Georgetown, Md.21930
Sassafras River, Md.
dockbumdan is offline
The Following User Says Thank You to dockbumdan For This Useful Post:
blavin (06-09-2014)
post #4 of 23 Old 06-08-2014
Over Hill Sailing Club
smurphny's Avatar
Re: Yanmar 3GM30F
How bad is your hunting? Can you see an actual change on your tach? I sometimes get a hunt (same motor) but it's barely noticeable and can be eliminated by changing rpms just a smidge. I think sometimes sympathetic vibrations can be mistaken for the engine hunting. Have you checked your coupling alignment lately? Prop for dings? Cutlass? I run at 26-2800 rpm and feel 3k constantly is a bit high but a lot depends in the individual set-up.
smurphny is offline
post #5 of 23 Old 06-09-2014 Thread Starter
Re: Yanmar 3GM30F
Will check the coupling...good suggestion ! Hunting at 2800-3000 then drops to 2000-1500 after an hour of motoring. Thanks for your input...
blavin is offline
post #6 of 23 Old 06-09-2014
smurphny's Avatar
Re: Yanmar 3GM30F
"Hunting" usually refers to cycling rpm up and down. If you are just dropping rpms, that's a lot different. Can you make it regain rpm by throttling up? Maybe just linkage? If you can't get it above 2gs, there's something wrong with the engine itself, probably a fuel blockage or air leak. Did you check all the bleeders? There is one behind the rubber water line by the injector pump. Make sure all the banjo fittings are tight, fuel filter cup is seated well, filters are clean. Air leaks can be insidious problems to find. Is your tank clean? If it has a screen on the end of the dip tube, losing rpms from fot clogging it is a classic symptom.
smurphny is offline
post #7 of 23 Old 06-09-2014 Thread Starter
Re: Yanmar 3GM30F
Yes, am losing rpm's....after running at 3,000 drops to 1500 then rises again and repeats...only happens after running for about an hour.....all the other issues you've mentioned have been attended to...more then once...it's driving me crazy plus missing out on fabulous boating weather !!
blavin is offline
post #8 of 23 Old 06-09-2014
Re: Yanmar 3GM30F
Tank vent clear?
Capt Len is offline
post #9 of 23 Old 06-09-2014 Thread Starter
Re: Yanmar 3GM30F
Blown out and cleaned....done everything...some twice !!...Thanks
blavin is offline
post #10 of 23 Old 06-09-2014
smurphny's Avatar
Re: Yanmar 3GM30F
I've had two instances of similar problems. The first one drove me nuts. There was a hairline crack in the crappy plastic dip tube elbow that goes into the fuel tank. It's not in a spot where it's easy to see and the crack was almost invisible. I wrapped the entire thing with epoxy and fg cloth neatly and it's better than new. The second instance was from fot in the fuel tank. The fill tubes on some tanks have a screen over the end at the bottom of the tank. It clogs easily. I took the fill tube out and poked much larger holes in the screen. Some people recommend taking the screen off altogether. Your regular filters catch dirt where it's easy to remove. Taking the dip tube out also let me siphon out any remaining contamination. Your problem sounds VERY much like this second one because the engine does not die, it just loses rpm. Hope this helps. These things are like a puzzle
smurphny is offline
Bleeding a Yanmar 3GM30F jlmarra Gear & Maintenance 6 07-12-2015 09:38 AM
Oil for Yanmar 3gm30f? carlager Diesel 4 11-27-2013 06:32 AM
Yanmar 3gm30f secondary filter carlager Gear & Maintenance 9 06-14-2013 06:56 AM
Yanmar 3GM30F aa3jy Diesel 7 11-23-2009 08:45 AM
Yanmar 3GM30F Bill Mc Gear & Maintenance 30 11-28-2007 07:51 PM
