Fuel Filtration for Yanmar 2qm15 - SailNet Community
post #1 of 4 Old 06-09-2014 Thread Starter
The fuel filter on my 2qm15 is rated for 10 to 15 microns. Ahead of that I have a racor filter. Is a 2 micron filter OK at this location or should it be 30 microns. Thanks
weephee is offline
post #2 of 4 Old 06-09-2014
RichH's Avatar
Re: Fuel Filtration for Yanmar 2qm15
Typical series fuel filtration for Yanmars: Tank --> 30然 Racor (if historically the 'downstream filter system' often fouls)--->10然 Racor---> 17然 (10-15然 is ok) engine mounted 'guard' filter ---> engine.
2然 is gross overkill, .... will need to be changed-out VERY frequently and/or will 'plug' easily if there is any excess contaminant, and will put an immense overload on the engine's lift pump.
RichH is offline
post #3 of 4 Old 06-09-2014
JimsCAL's Avatar
On my 3GM30F I have a 30m Racor then the engine mounted filter. You want the first filter to remove the larger stuff so the next one can remove the finer stuff without plugging quickly.
JimsCAL is offline
post #4 of 4 Old 06-10-2014 Thread Starter
Thanks for the replies. I've ordered the 30 micron filter
weephee is offline
yanmar 2qm15 fuel problem pfirth Diesel 11 05-11-2011 01:23 PM
Yanmar 2qm15 fuel problem pfirth Diesel 10 04-09-2011 02:20 AM
yanmar 2qm15 fuel problems pfirth Diesel 6 04-01-2011 02:40 PM
Yanmar 2QM15 fuel consumption? 30Irwin Diesel 9 09-05-2009 12:17 AM
Yanmar 2QM15 - Changing the Fuel Filter backcreeksailor Gear & Maintenance 15 06-04-2009 08:36 PM
