Cs-36t fuel tank leak - SailNet Community
post #1 of 6 Old 06-16-2014 Thread Starter
soyuz's Avatar
My fuel tank as a leak and after trying to repair it by building a new bottom still no luck.
Where can i buy a new one ?
S/V Grey Goose
Cs 36
home port: Gaspésie.
soyuz is offline
post #2 of 6 Old 06-16-2014
Freedom 39
FarCry's Avatar
Re: Cs-36t fuel tank leak
What do you want your new tank to be made out of? Are you trying to find the OEM? Moeller has numerous plastic tanks. RDS has numerous aluminum tanks. A local welding shop could probably use your existing tank as a template and make a replacement. There are also numerous manufacturers of coatings that can be put on the inside of your tank. Aero Tec Labs makes soft tanks that can be custom made to fit inside your existing tank.
FarCry is offline
post #3 of 6 Old 06-16-2014
Maine Sail's Avatar
It is a custom build at this point. I would urge going up to 1/8" wall thickness and having extra tappings installed for such things as a future heater or fuel polishing system.. Any tank maker can make it from exacting measurements and drawings....
______
-Maine Sail / CS-36T
Maine Sail is offline
post #4 of 6 Old 06-16-2014
ASA and PSIA Instructor
Ditto the custom build. Be sure when re-installing to provide better drainage so the new tank will last longer, has your hot water heater been leaking?
You can find threads about removing the tank, some talk about cutting it into pieces, but if your engine mounts or hot water tank or steering are original or you have any backed up engine work, the tank comes out very easily after the engine is out...Just line up the bank loan in advance.
sailingfool is online now
post #5 of 6 Old 06-16-2014 Thread Starter
soyuz's Avatar
Thanks guys I am going to do some phone calls tomorrow.
Just hope it wont be too expensive ...
S/V Grey Goose
Cs 36
soyuz is offline
post #6 of 6 Old 06-17-2014
jimrafford's Avatar
Atlantic Coastal Welding. speedytanks.com in new jersey made a replacement for out 36t. They had the dimensions and shipped to me in about a week. Think it was around $600.
Jim
S/V Deja Vu
CS 40
jimrafford is offline
Fuel Leak? mikefossl Diesel 2 02-17-2012 11:23 PM
Ericson 27 fuel tank leak vindauga Ericson 3 07-07-2006 03:42 PM
fuel tank leak gart Gear & Maintenance 1 03-23-2004 12:04 PM
tiny leak in black iron fuel tank kathyspike Gear & Maintenance 2 11-17-2002 12:05 PM
Fuel Tank Leak silversea Gear & Maintenance 1 02-13-2002 04:05 AM
