Yanmar diesel fuel filter water separator - SailNet Community
post #1 of 9 Old 06-27-2014 Thread Starter
I have a 1983 Irwin Citation 31 ft. Yanmar 2GM.
I was trying to clean the water separator and I dropped it ... in 40 ft of water.
Where can I get a similar product for a reasonable price?
I saw online a Volvo Penta for $239. I am hoping to get something cheaper.
Thanks a lot
oksailor is offline
post #2 of 9 Old 06-28-2014
JimsCAL's Avatar
Re: Yanmar diesel fuel filter water separator
Why not a Racor?
JimsCAL is offline
post #3 of 9 Old 06-28-2014
RTB
TROUBLE
RTB's Avatar
Get a diver to find the dropped part. Probably cost you $50-$75.00. Personally, I second getting a Racor, and get rid of the water separator.
Ralph
Our temporary Galveston home | sailing away with R & B
S/V FUGUE
HUNTER 36
KEMAH, TX
RTB is offline
post #4 of 9 Old 06-29-2014
Over Hill Sailing Club
smurphny's Avatar
This is the one I installed last year to replace the see-thru bottom RACOR which was no longer legal in the engine compartment:Racor Spin-On Series Compact Fuel Filter / Water Separator Assembly
smurphny is offline
post #5 of 9 Old 06-29-2014
RichH's Avatar
Yanmar engines are found on many tractors .... simply go online and do websearch: "tractor+parts+Yanmar".
Such a replacement engine mounted filter for your engine (not a filter-separator) should have a M removal 'rating' of 15-17M.
However, if what you lost overboard is the small 'filter' thats mounted ON the engine it will be a very poor 'water separator' as its not located in bottom-most portion of the fuel delivery tubing where water will accumulate. A Water separator NEEDS to be placed in the VERY LOWEST portion of the fuel delivery piping.
If you NEED a water separator due to your history of operation, then I suggest simply to put an EMPTY filter housing with an integral bottom/'bowl' drain cockk valve in the lowest level of the fuel delivery system. Using an empty filter housing (with drain cockk) to trap water is known as a "knock-out pot".
RichH is offline
post #6 of 9 Old 06-29-2014 Thread Starter
I will probably go with a Racor with a see-through bottom.
A couple of issues have been touched here:
- water separator in lowest point of fuel supply. Mine was in the highest point, and still had 400 cc of water in. I purchased the boat 3 months ago and did not check it prior thoroughly.
- a diver is not an option since the bottom has 3-4 ft of silt ...
I ordered today the filter 301050 from Defender (best price around).
One more question: my engine stopped - that's how I realized I had too much water in the separator. Should I just install the new separator and start the engine, or do I need to "bleed" it ? Obviously, diesel engines are not my strength.
Thanks again
oksailor is offline
post #7 of 9 Old 06-29-2014
RichH's Avatar
Id recommend that you get the water out of the tank, fuel lines (especially the lowest part of the fuel lines) and any other filter in the 'set' before you restart ..... hitting a HOT injector(s) with a 'slug' of water can 'shatter' the tips of the injectors. Water - drain it, and then BLOW all the system 'tubing' out.
With most Yanmars you dont have to bleed the whole system to restart ..... just bleed 'all' from the tank, the filters, the engine 'guard' filter .... everything up to but not necessarily including the high pressure fuel injection pump nor the injectors. 99% of the time this will air bleed a Yanmar as the injection pump and the injectors can handle 'slugs' of air.
Be sure to 'lubricate' the filter gaskets with fuel oil when reinstalling; dont overtighten the flare fittings or (god-awful) 'compression' fittings as they are easily 'cracked' by gorillas with wrenches.
RichH is offline
post #8 of 9 Old 06-29-2014
smurphny's Avatar
If you can get to the fuel tube that screws into the top of your tank and unscrew/remove it, then you can effectively siphon (or outboard hose squeegee any water/fungus,and misc, fot out of the tank.
smurphny is offline
post #9 of 9 Old 06-29-2014 Thread Starter
Thank you for the advice.
oksailor is offline
Diesel/Water Fuel Filter System Ski Sail Diesel 8 05-06-2014 09:21 PM
installing a fuel filter/separator blisscloud9 Diesel 3 05-07-2011 08:01 PM
Universal diesel Kobuta oil filter is a Fram PH3593A looking for diesel fuel filter dave hirsh Diesel 4 06-07-2010 09:01 AM
Fuel filter/water separator Waltthesalt Diesel 8 01-08-2010 09:00 PM
Diesel Filter/water separator Gulfislander Gear & Maintenance 2 04-27-2009 11:51 PM
