injection timing yanmar 1gm10 - SailNet Community
post #1 of 4 Old 06-28-2014 Thread Starter
Remember you're a womble
PaulinVictoria's Avatar
So I'm at the boat trying to adjust the timing. Dumb question time. If the injection pump squirts fuel after the timing mark has gone past, is it retarded and I need to remove shims, or advanced and I need to add them?
Orange Crush
1974 C&C27 MkII
PaulinVictoria is offline
post #2 of 4 Old 06-28-2014
Re: injection timing yanmar 1gm10
Not much experience on that engine but know that is retarded. One standard shim equals one degree. Putting in shims will advance it. Makes the pump piston meet the cam follower sooner.
Capt Len is offline
post #3 of 4 Old 06-28-2014 Thread Starter
Well turns out it needed less shims. Adding shims moved the timing even further off. Managed to get it close (within a few degrees) and that was the best I could manage since there are no shims at all there now, runs all the way to the redline now with no white smoke, and started on the button. That'll do.
Orange Crush
1974 C&C27 MkII
post #4 of 4 Old 06-29-2014
fryewe's Avatar
Congratulations Paul on dueling this dragon and winning.
The web makes everywhere the same place. - Fred Reed, from "Fred on Everything"
fryewe is offline
Yanmar 1GM10 runaway? PaulinVictoria Diesel 79 08-01-2014 09:46 PM
Yanmar 3gm30f Fuel injection limiter carlager Diesel 4 01-03-2014 11:36 PM
Yanmar YSE 8 fuel injection issue? sadie anne clawe Diesel 12 04-26-2013 01:49 AM
Yanmar 1GM10 Overheating BayLAzr Diesel 8 07-29-2011 03:40 PM
Yanmar 2GM injection pump issue? kcford Diesel 10 05-03-2011 11:03 PM
