Gauges for Yanmar YSB-8? - Page 2 - SailNet Community
post #11 of 18 Old 07-05-2014
One of None
deniseO30's Avatar
Re: Gauges for Yanmar YSB-8?
I've never even seen metric pipe anywhere in my trade HVAC, not that I ever thought of looking for it., my dad was a plumber too. so the MM is the size but not actually differen't from what is used here in the USA? seems so.
Diameter Nominal
DN
(mm) Nominal Pipe Size
NPS
(inches)
6 1/8
8 1/4
10 3/8
15 1/2
20 3/4
25 1
32 1 1/4
40 1 1/2
50 2
65 2 1/2
80 3
My last project!
deniseO30 is offline
post #12 of 18 Old 07-06-2014
JimsCAL's Avatar
Diameter Nominal
DN
NPS
(inches)
6 1/8
8 1/4
10 3/8
15 1/2
20 3/4
25 1
32 1 1/4
40 1 1/2
50 2
65 2 1/2
80 3
Metric pipe sizes are very close, but threads are different. Slightly different number of threads per inch for the same OD pipe, and threads have a slightly different shape. See ISO 7-1. From the Engineering Toolbox online:
"NPT threads may look similar to ISO 7/1 threads. However, ISO and NPT threads should not be mixed. ISO threads have 55o taper angle versus 60o for NPT. The NPT root and crest configurations are also different from ISO. For ISO threads pitch is usually measured in millimeters (may be expressed in Inch). The pitch are different."
JimsCAL is online now
post #13 of 18 Old 07-15-2014
cptjak's Avatar
Come on doesn't someone know the metric pipe thread size on our
Yanmars.
cptjak is offline
post #14 of 18 Old 07-16-2014
JimsCAL's Avatar
Yanmars.
Unless someone has actually done this, not likely. Try your local Yanmar dealer or Mack Boring.
Mack Boring & Parts Company - Reliable Power. Everywhere.
post #15 of 18 Old 07-26-2014
cptjak's Avatar
Ok found out VDO makes a metric thread universal kit
With different size adapters for oil pressure and water
temp. That is what I am going to purchase.
cptjak is offline
post #16 of 18 Old 07-27-2014
lillia28's Avatar
Location: Central New Jersey, sailing on the Navesink River and Sandy Hook Bay mostly.
The sending units from later model Yanmars will fit the YSM. It is a common upgrade. Check with Mack Boring or Torrensen or Hoye Tractor.
I've seen kits from Hoye Tractor parts. http://www.hoyetractor.com/PROD/TS-1470.htm for the gauge sender, $15.75. They also sell an adapter so you can use the sender from the gauge kit for about $10.00.
The alternator from later GM Yanmars has a tach terminal, and is a straight bolt in, same size case etc. Look for Hitachi LR155, 55 amp. You may need to change out the fans, as the YSM is "reverse" rotation. The YSM had a LR 135, 35 amp. The 155 will use a 1/2 horsepower more than the 35 amp, when it is putting out its full 55 amps, which is not that often. You can find the LR155 on line for about $100.00. For some reason it is a few dollars cheaper than the LR 135.
I have a YSM 12 which is why I did the research.
Lou
Last edited by lillia28; 08-11-2014 at 03:15 PM. Reason: additional information and clarity
lillia28 is offline
post #17 of 18 Old 10-23-2014
Jerry-Bayfield-Wisconsin
Originally Posted by cghubbell View Post
I have a Yanmar YSB-8 engine on my 1977 CS27, which thankfully runs like a top. The engine panel, however, is in rough shape and due for a make-over.
As I understand it, the engine system has sensors for oil pressure, engine temperature, and voltage (off alternator). I'm wondering if the existing sensors can feed an analog gauge rather than the dummy lights they are currently connected to. If not, is there a moderately painless way to get this information in the right format? I am most interested in looking to have a temperature gauge and oil pressure gauge.
I also want to add a analog tachometer, but I believe that I have to have my alternator modified for a pickup before I can do this. (I don't like the look of the tiny-tach, which I think is my only alternative).
Would appreciate any guidance, as I don't have much information on how these work.
Thanks in advance,
Chris
I am about to create a new engine control panel for my boat's Yanmar YSB-8. I have purchased some inexpensive analog gauges (with sending units) from Amazon.com. (They're only about $15 each--they may be too cheaply made--we will see.) I plan to parallel the existing binary (on/off) sending unit output to the warning lights with the new analog gauge sending units so that I can SEE the pressure and temperature and also have a warning light/buzzer. I think the pipe fittings are 1/8th inch NPT. I can let you know how it all worked out next spring when I launch the boat in Lake Superior. Stay in touch. By the way, instead of a tach connected to the alternator, I ordered a hand-held tach that responds to a reflective patch on the engine pulley. (Normally, I don't need to know the exact RPM after I adjust the full-throttle and idle speeds.) The tach only costs about $20 on Amazon.com.
JerryMeyer is offline
post #18 of 18 Old 10-26-2014
A long time ago I fitted an oil pressure guage and oil pressure alarm to my old Volvo MD17C.
I put a wee T-piece in to the oil pressure port on the motor and fitted an oil pressure guage on to the bulkhead of the engine room (my engine room is open on one side so I can see the guage).
To the other side of the T-piece, I fitted the oil pressure switch again, and used it to close a relay (taken from a scrap BMW) that in turn called in a standard automobile horn (taken from another scrap automobile).
I put the horn on an engine room enable/disable switch so I don't get deafened if my head is in there during maintenance with motor stopped and ignition on. The horn is bolted to another engine room wall. It is very loud so anyone can hear it, anywhere on the boat. You need the relay as the oil pressure switch cannot carry the current for the horn.... the switch calls the horn in, but does not carry the current for the horn.
Remember to fuse the circuit for both horn and relay. The only melt-down I ever had on board was the one circuit I did not fuse on the boat.... the oil pressure switch.... and the battery just fried the cable in seconds.
With that lesson learned, it is still working, 20 years on.
The lot cost me about $30 for the (new) guage (0 to 60 psi), and about $10 for the other bits. When cold, my old motor at 2000 rpm will raise about 60 psi with new oil (15W/40 mineral), and new oil drops to about 35 psi when hot, and at the end of season to about 30 psi when hot.
Rockter is offline
New Gauges? Kalina-Lona Atomic 4 4 09-19-2013 02:02 PM
Ysb 12 - Ysm 12 injector question giordi0 Diesel 0 07-02-2013 10:00 PM
Rebuilding a Yanmar YSM-12 using YSB head superiorvoyager Diesel 7 12-09-2012 06:09 PM
Teleflex Gauges clarity36 Electrical Systems 1 11-07-2010 10:30 AM
yanmar ysb 8 ecarson General Discussion (sailing related) 0 08-25-2010 02:08 PM
