Westerbeke 30B motor clicking, high amp draw - SailNet Community
 3Likes
post #1 of 12 Old 07-11-2014 Thread Starter
Hi all,
Just got a Shiny new to me Pearson 30 that was retrofitted with a mid 90's westerbeke 30-B 3 cylinder inboard diesel. On our maiden voyage we sailed her home and the battery died, which killed the engine. I'm thinking ok alternator must be bad cause that should never happen. But then after installing a fresh AGM battery I notice that every time we turn on the battery switch there is a clicking sound from the engine compartment somewhere too far to stick my head in all the way. There is also an amp draw that makes my multimeter alarm- so greater than 10amps dc. This is before I turn on any switches on the main breaker panel.
So, what clicks consistently once or twice a second and draws > 10 amps?
Thanks!
mkeSailor is offline
post #2 of 12 Old 07-11-2014
Learning the HARD way...
eherlihy's Avatar
Re: Westerbeke 30B motor clicking, high amp draw
Originally Posted by mkeSailor View Post
Hi all,
Thanks!
Are you sure that this isn't an Atomic 4?
A diesel engine does not require any electrical power to run.
The two things that will CLICK on a diesel are the starter solenoid, and (if you have one) the electric fuel pump.
eherlihy is offline
post #3 of 12 Old 07-11-2014
There is a circuit breaker at the rear of the engine, the button is facing forward, on the starboard side of the engine right beside the fuel filter and solenoid. Did you check it? You could have a short in the wire harness somewhere. Check the wire harness and follow it around the engine looking for any exposed wire. I hope this helps.
SVTatia is offline
post #4 of 12 Old 07-12-2014
chucklesR's Avatar
Fuel pump. WB 30's have and electric fuel pump as opposed to the normal mechanical pumps driven by the cam shaft. If you don't have a manual for the engine you can download one from their website.
As to the 10amp draw, should be 1 amp check the scale on your multimeter. If it really is 10 then you have a short draining juice.
Tempest likes this.
chucklesR is offline
post #5 of 12 Old 07-14-2014
Chuckles is right, the fuel pump makes a clicking noise as it is electric and self-bleeding. However, the clicking should only be heard when you turn on the ignition switch, and according to the OP, the noise is heard when he turns the battery switch.
I would pay close attention to this, just to be on the safe side - a short in the engine room could be catastrophic.
SVTatia is offline
post #6 of 12 Old 07-14-2014
Sounds like an electric pulse pump Should not be wired except thru the engine control switch. Also would explain why engine died when battery died.If it's really 10 amps, something should get pretty warm pretty fast. I'd stick my head in and learn about the boat.
Capt Len is online now
post #7 of 12 Old 07-14-2014
Are you turning the ignition switch to the off position after you kill the engine using the T-handle. ( engine kill) Or are you fitted with a key shutoff?
If not the pump will continue to run, and the engine instruments will remain on.
Capt Len likes this.
tempest is offline
post #8 of 12 Old 07-14-2014
mbowser's Avatar
I wonder if the 'idiot' buzzer is broken and he has the ignition switch in the 'on' position even though he is sailing. While I was trying to get my w21 started over the past few days I temporarily unplugged the wire from the buzzer because it was annoying me. That position activates the fuel lift pump (and the buzzer if connected) and is certainly what is causing the clicking, but I'd be surprised if it drew 10 amps.
mbowser is offline
post #9 of 12 Old 07-14-2014
Maine Sail's Avatar
Also be sure your glow button is not stuck. They are fairly prone to sticking as they age..
______
-Maine Sail / CS-36T
Maine Sail is offline
post #10 of 12 Old 07-15-2014
No experience with your engine. However, VW diesels I have owned & worked on had a fuel supply solenoid powered by 12volts, but 10 amps is way more than they would draw. Glow plugs may draw about 10 amps, if your engine has them? If so & they are fed by a solenoid, maybe it is bad?
Maybe a defective starter solenoid?
Paul T
dabnis is offline
Westerbeke 30B Bad Fuel? JaredJ Diesel 7 06-23-2015 09:44 AM
ESPAR High Amp Draw On Start-Up Shack Gear & Maintenance 11 01-22-2014 04:42 PM
Westerbeke 30B Deceleration Stumble/Stalling lenkrauss Diesel 9 08-05-2012 08:50 AM
Westerbeke 30B 3 Temp gauge gone wild... LeftWinded Diesel 2 05-23-2011 07:54 AM
Need advice on engines - Westerbeke 30B or Yanmar 3YM30? Terry60 Diesel 15 01-31-2010 01:51 AM
