Frozen Volvo MD1 - SailNet Community
post #1 of 5 Old 07-25-2014 Thread Starter
Frozen Volvo MD1
1972 Volvo MD1 aboard my Westerly 28. Went to hand crank it this Spring and the darn thing was seized. Managed to break it loose pretty easy (turned the flywheel backwards) but two week later, same thing. This time the thing seems seized up tight.
Pulled the injector and sprayed a healthy amount of PB blaster into the cylinder and took a massive wrench to the flywheel but the thing still won't budge.
Where do I go from here? Thanks for any help!
ReddOne is offline
post #2 of 5 Old 07-25-2014
Re: Frozen Volvo MD1
Rebuild sorry.
Zen is a matter of recognizing reality.
desert rat is offline
post #3 of 5 Old 07-25-2014
KROIL much better than PB Blaster imho. But probably need rebuild
sulli is offline
post #4 of 5 Old 07-26-2014
RichH's Avatar
Where to go ....
Check from where the cooling water is leaking into the combustion chamber
1. Blown head gasket
2. Pin hole in the exhaust manifold between the 'gas side' and the 'water side'.
3. Injection elbow mounted too close the the boats water line.
If this engine is fresh water cooled and the fresh water also cools the exhaust manifold, you can use a fluorescing dye in the cooling water which will 'glow' when 'black light' is shown into the water. The fluorescence will show that carbon monoxide from the combustion chamber is present in the water.
Exhaust manifolds when they age and due to formation of 'slab rust' can easily 'back leak' into a combustion chamber. Easy to check - remove the manifold and do a pressure hold test.
Pressure hold ... apply air pressure to the water side of the manifold with the water inlet and out blocked. Apply a press. gage and gas-tight shut off valve between the air source and the manifold. Youre looking for the gage to slowly show a drop in air pressure over time with the shut off valve closed after pressurizing. Can be done with water pressure but isnt as sensitive as air pressure decay.
Until you find where the water is leaking into the engine and affect its repair , I suggest that you do NOT use the starter to turn over the engine; but rather, 'gently' and without FORCE hand crank the engine by hand to verify that the piston rings are not 'frozen' in their grooves on the piston(s). If theyre frozen and you 'force' the engine you will SURELY break the rings. Once you verify that the rings are 'free' by easy hand turning the engine, then you can proceed with the use of the starter. Use a 'strap wrench' on the crankshaft pulley with the compression release 'open' to check .... 'gently' rocking back and forth to free the rings; do not 'force' a frozen engine unless you want to put in new piston rings.
RichH is offline
post #5 of 5 Old 05-30-2015
Good Crew
mdriscol's Avatar
Hello ReddOne,
My MD1 did pretty much the same thing last year. What did you finally do with it?
I am tired of fixing this powerplant and contemplating replacing with electric as my boat is only 20 feet long, about 3000 lbs.
Maureen
Lilliput
mdriscol is offline
Marina Frozen budvar General Discussion (sailing related) 5 02-10-2014 06:36 PM
Frozen Bilge caberg Gear & Maintenance 21 12-24-2012 10:23 AM
volvo penta md1 starter generator boz86 Diesel 2 07-02-2012 12:24 PM
Frozen bilges Minnewaska Gear & Maintenance 15 01-25-2011 02:28 PM
Frozen Westerbeke VIEXILE Gear & Maintenance 4 03-11-2004 07:39 AM
