Yanmar 4JH4AE, KM35P trans vibration - SailNet Community
post #1 of 6 Old 07-29-2014 Thread Starter
Hi Folks
Hi Folks
Have Beneteau 40 with yanmar 4JH4AE engine, KM35P cone clutch transmission.
Had transmission problem. The cone clutch was lapped and trans put back in. But I now get a vibration set in at 1200 rpm which goes away at 1600 rpm.
Would love to have some ideas before mechanic comes to look at things in two days time.
Could alignment problem come and go over this sort of range or could there be other causes.
thanks, JohnB40
JohnB40 is offline
post #2 of 6 Old 07-30-2014
kd3pc's Avatar
Re: Yanmar 4JH4AE, KM35P trans vibration
sounds like an out of balance shaft or prop, alignment - if done correctly, should be good across the operating range.
You can turn the shaft coupling 90 or 180 degrees, after marking it, to see if the problem changes or have a reputable shop check the prop and shaft.
Assuming it did NOT happen prior to the repair? Loose mount?
kd3pc is offline
post #3 of 6 Old 07-30-2014 Thread Starter
Hi folks
Getting good comment ... thanks.
The vibration started after tranny repair 6 weeks ago. Problem is I left day after for a 6 week sail. My recollection is it was there from the start and we tried to avoid that 1200 to 1600 rpm range where it occurred. Could have become worse over the 6 weeks away but not sure.
Should have also said the vibration does not occur with engine in neutral.
I've no idea if the couplings on transmission and prop shaft were reconnected with the same holes matched up .... sounds like that might be a possible thing worth trying? That is, rotate shaft 90 degrees and rebolt. Do again etc to see if one position is good .... as you see I'm no expert!
thanks, JohnB40
JohnB40 is offline
post #4 of 6 Old 07-30-2014
kd3pc's Avatar
thanks, JohnB40
Yes, mark the "current" position, and then rotate the shaft 90 degrees at a time.
kd3pc is offline
post #5 of 6 Old 07-31-2014
Try a feeler gauge between the flanges .
Capt Len is offline
post #6 of 6 Old 08-03-2014 Thread Starter
Thanks folks. I feel much better informed ... never a bad thing. It does seem to have been just the alignment issue. Vibration seems to have been fixed.
Still concerned why Yanmar cone clutch would crap out after such a short period of use ... the KM35P trans seems to have a load of problems from searching the web. It was run as per Yanmar instuctions ... allow to spin while sailing. Ensure clutch cable adjusted. Change oil etc
JohnB40
JohnB40 is offline
Transmission Yanmar KM35P problem JohnB40 Diesel 8 10-15-2015 05:10 PM
Yanmar super vibration meanderboy Diesel 47 12-18-2014 09:11 PM
Yanmar 4JH4AE catastrophic breakdown experience eisselhardt Gear & Maintenance 32 04-09-2014 08:06 PM
yanmar vibration at low rpm 17spyglass17 Diesel 2 03-04-2014 12:42 PM
Dexron ATF in my Yanmar Trans Gear? jason3317 Gear & Maintenance 29 12-16-2008 08:02 PM
